All Activity
This stream auto-updates
- Past Hour
Arithmetic behavior causing a quick zero
Saxony Thermal replied to Saxony Thermal's topic in Mitsubishi
Thank you! I will study this. -
vasik joined the community
Vieiramg joined the community
Muggs joined the community
- Today
Conveyor flow logic
Raincor replied to brisutterfield's topic in Allen Bradley / Rockwell Automation
Is this file still available? -
Raincor joined the community
Ethernet/IP communication with Allen Bradley PLC in network
pturmel replied to Deeksha's topic in Allen Bradley / Rockwell Automation
Right, that means your PLC "owns" those devices. Most I/O devices do not permit many, or any, configuration changes while a scanner owns them. You will need to inhibit those modules in the I/O tree to be able to write configuration attributes. -
skakke joined the community
Are you the Steve Bailey that worked on a project with me for New Jersey Transit?
BerkshireMike started following Steve Bailey
BerkshireMike joined the community
Roy_he joined the community
Deeksha replied to Deeksha's topic in Allen Bradley / Rockwell Automation
Currently router I am using here doesn't support port mirror. I have requested team to get the router supporting port mirroring. I should get that sometime in next week. I guess till then I won't be able to debug "Embedded service error" in detail, I am stuck here, I guess. "Owned" by something - didn't understand this? Studio 5000 I/O device tree snap is attached. Device 1 and Device 2 are the I/O devices in which we have implemented Ethernet/IP communication. -
DmhskcCor liked a post in a topic: Allen Bradley FAQ
DmhskcCor joined the community
Игл joined the community
- Yesterday
Thank you ! I was able to get it linked . I'm new to CC-Link , is the Operation Test tab in the CC-Link Diagnostics how you test your connection between the PLC and other station connected ?
I don't know why, but it seems that I had not yet found/seen the Structured Programming manual. I had a few other manuals but not this one 😅. I understand the functions better now. Thanks! The D8340 "bug" has also been solved! Just like the C250/C251 problem, I found out that the Chinese clone has a different device number for the actual pulse count. I used a switch for enabling a DRVI command while scrolling through the device list until I saw a value changing. For this PLC type I have to use D8132 instead of D8340.
Thanks for the reply - will have a look at this over the weekend.
Thank you so much guys, the information what you guys shared are very useful. I made a little example program, to check how is it working. Its working properly I guess. @pturmel Could you please share with me an example ladder logic, about your solution. Some part of that dispriction is not clear to me yet. Thanks ahead.
Did the error start suddenly or is this a new system? Check station & baud rate settings on each device, and resistors where appropriate.
photovoltaic started following SMS messaging from a CJ2M-CPU31
This isn't supported, you'll need to utilize a 3rd party service like textbelt.com and program the PLC to utilize their API. I don't have any examples for the CJs, just the NJ/NX PLCs. If you only need 1 or 2 different SMS messages there are some products that can send out SMS messages based on digital inputs(RT100 for example). Alternatively many cell modems support AT commands which are very easy to utilize with socket services and allow you to customize the recipients and message contents. Socket Services on a CJ: https://www.myomron.com/index.php?action=kb&article=1396
Hey guys, I'm having trouble getting my data link started in GX Works3 . Does anybody know how to get rid of the errors for the slave stations ?
mr.G started following CC-LINK CONNECTION
I just discovered that my Mikrotik router can do packet captures for me on selected interfaces and stream the results to a Wireshark instance on my laptop. No need for the port mirror at all (but HW offload has to be disabled on the affected ports). -
Joe E. liked a post in a topic: Ethernet/IP communication with Allen Bradley PLC in network
pturmel liked a post in a topic: The Integration of PowerFlex Drives in a Schneider Control System
If you have to track in arrays of larger data structures, using ring buffer techniques can greatly reduce CPU utilization. Using the shift instructions, or COP for shifting, is quite expensive. Instead of shifting, you add to an integer subscript for the load point to manage where you are in the array. And wrap around the end. For physical items on the conveyor a known distance downstream from your load sensor, you simply add to the load point subscript the constant for the distance (in array elements), wrapping it around, too.
BobLfoot replied to Asrarmeryem's topic in Modicon / Telemecanique / Schneider Electric
I doubt this will be much help, but AB drives usually have a Status Word, Command Word and Data Links between themselves and the PLC. The Powerflex Manuals will describe the Status Word, Command Word and Data Links in detail. The trick will be to find how in Schneider Memory / Tag Structure the EDS has mapped them. The HIM of the drives will also be useful as they will tell you when you have supplied th appropriate Stop/Enable signals to allow the drives to runa t all. Speaking of which, have you run the drives from the HIM to confirm you're enables and stops are wired correctly?- 1 reply
1
I've done this with covneyors and no encoder just a once per revolution of the driven shaft prox. So 5 meters might become 500 or 5000 pusles of the sensor. Then create an array of length 600 or 6000. I was usually using DINTS because I had to track more than just good/bad. Each prox pulse I check the bad sensor and load position 6000 of the array with a 1 or zero, After that I COP Array[1] Array[0] moving everything one position. A little trail and error tells me that due to rounding errors and such the unload/stop position is actually 98 or 997 not the 10 or 100 I calculated. Hope this napkin description makes sense. I'm sure it can also be adapted to using the encoder values.
No question about that at all. But I am often not on-site, so a port mirror that can be configured remotely has great value. And, sometimes, simply moving connectors masks a problem. -
VFD Guy replied to Deeksha's topic in Allen Bradley / Rockwell Automation
Port mirroring is complicated. Either find an old hub or use a sniffer is the easiest. I use shark tap. -
VFD Guy started following Ethernet/IP communication with Allen Bradley PLC in network
Troubleshooting problems in cases like this. Most modern managed switches have features to help technical staff connect wireshark to specific ports, so that sources of bad behavior can be examined unfiltered, and without relying on an intermediate two-port switch. Actual DLR, though, is awesome. - Last week
BobB started following SMS messaging from a CJ2M-CPU31
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this and are unable to assist.
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it says that for main power, 1ph 240VAC for rated current of 6.5A, and for controller power, 1ph 250VAC with rated current of 0.2A. will it be ok to use 6.5A fuse for main power and 0.2A fuse for controller power? or what calculation or table do I need to use to select proper fuses? Thanks,
thank you, my problem has been resolved
So, some more details. The BSL and BSR instructions operate on a rising edge of the rung enable. You would enable the instruction once every time the encoder turns enough for a part to have passed by. The last one I did is in a CompactLogix. I had to create a tag called "Track_Array" of type DINT[1]. The Array tag of the BSL instruction was Track_Array[0]. Its Control tag is a new otherwise unused tag and the source bit (for me) is an Always_Off bit. Length is the number of parts that can be on the conveyor plus a few. If the conveyor is more than 32 parts long, you'll want to have your Track_Array tag bigger. For example, DINT[2] will get you 64 positions. The one I did was anchored at the load station being station 0 so I used a BSL. If instead you want the end to be bit 0, you'd use a BSR instead. Doesn't really affect things other than how you think of it. Here's the rung with the BSL. CAM_00 is on once per machine cycle. In your case, you'd flash it once every time a part spot has passed by on the conveyor: Here, we set bit 1, which is where the servo loads the blanks: Here, we clear bit 8, which is where the finished parts fall out of the machine. Like I said before, I'm not 100% sure this is really the best way to proceed for you. It may make more sense to use a FIFO array. Use an FFL instruction every time a part passes by the sensor and an FFU every time a part arrives at the end position. Downside to using a BSL/BSR is if the parts can slip on the conveyor. If that's not an issue, the FIFO won't work if parts can be removed from the conveyor between the sensor and end. That's why it's good to have multiple tools in your belt.
If all you want is to store good/bad, use a bit shift array using a BSL or BSR instruction. High level description: You'll execute the BSL/BSR once per "interval" of the conveyor's movement. Let's say the end position is at bit 0 of the array and the sensor is at bit 20. The sensor will set/reset bit 20 of the array while the reject/whatever sequence looks at bit 0. A BSR is fired to shift the data automatically.
- Load more activity
