Kim Jessen
HMI panel / display for Siemens LOGO! 8 ethernet
10 posts in this topic
hi, I'm trying to find out what kind of HMI panels can be used for a LOGO!8 ethernet plc. are panels from simens that can be used... they are a bit expensive
Edited by Kim Jessen
Logo isn't really a PLC, it's intended to be a programmable relay.  A PLC would have more options for HMI.
I do not recall anyone other than Siemens making a small one to talk to Logo.
If you use LOGO!8 for V8 or later it can be set communication to be Modbus TCP Server then you can use any HMI Touchscreen that can use with Modbus TCP connection.
2 people like this
Good to know... haven't had the chance to use one in a few years...
Ok..
i bought a rs pro hmi panel.. but i can't get it to work.. can you help with some link to a youtube.. I have studied this video but I can't get it to work.
https://youtu.be/aHVdsKyDPP0?si=XHm4jFyBz8s3Kzlv
+ I also have this document.. but it doesn't really make sense... at least it doesn't work.!!
https://docs.we-con.com.cn/bin/view/PIStudio/PLC%20Protocol/Siemens/#HLOGOEthernet
17 hours ago, Kim Jessen said:
Ok..
Ask the HMI manufacturer for help, if they have  doc's how to make the connection.
yes.. they sent me the 2 things the movie and the pdf file
@Kim Jessen Do you need to connect PLC LOGO!8 to RS Pro HMI by ethernet connection alright?
RS Pro HMI seems use Wecon PIStudio Software for configuration. On your example video is configured with S7-1200 with S7 connection.
For use with LOGO!8 they can use with S7 connection too by compare LOGO!8 variable to be in DB1 like this link
https://www.promotic.eu/en/pmdoc/Subsystems/Comm/PLC/LOGO.htm
but you need to familiar with TSAP Local / Remote setting
I recommend to open Modbus TCP Connection on LOGO!8 then use Modbus TCP driver on RS Pro HMI is easier to connect it.
Hi everyone.. thanks for your input. I have given up and taken a different angle of attack..
I have invested in a s7-1212C plc. there I got connected. so that's where I continue. if someone comes up with a brilliant solution for the LOGO module, I think more people will be happy. but right now it's beyond my abilities.
