Posted 6 Aug 2010 I have lost and cant remake connection between GX Developer and QJ71E71 ethernet module. Is it all about Transfer setup or parametres or both.? I have changed to serial transfer to complete some work but it is very slow. Any help appreciated Share this post Link to post Share on other sites
Posted 6 Aug 2010 To understand what's happend is need to analize the Transfer Setup then module setup. Of course, to check module setup is need to connect with PLC via programming port. What have you meant when said "it is very slow"? Q-series programming port works up to 115200 kbit/s and it's enough for normal working. Share this post Link to post Share on other sites
Posted 6 Aug 2010 But in first to find the source of problem is necessary to do some ping. Share this post Link to post Share on other sites
Posted 6 Aug 2010 Screenshots of both parameter setup and transfer setup would also be good to help us help you..... Share this post Link to post Share on other sites
Posted 6 Aug 2010 (edited) The most common mistake is that the network and station nr of the QE71 match that of the PC in the tranfer setup. By default the network and station nr of the Qe71 are: Network nr :1 Station nr : 1 Make sure that the in the transfer setup the PC side has the same network nr but a different station nr. For instance 60 But some screen shots would be helpful to locate the problem. Edited 6 Aug 2010 by Gambit Share this post Link to post Share on other sites
Posted 6 Aug 2010 Hi doppy, Try look at this. Hope this can help you Best regards Dariusch Share this post Link to post Share on other sites
Posted 6 Aug 2010 I meant its slow on serial compared to ethernet. Thanks a lot for your help Paul Share this post Link to post Share on other sites
Posted 6 Aug 2010 Thanks a lot, I think with the info I can sort it Share this post Link to post Share on other sites
Posted 6 Aug 2010 thanks again Dariusch Regards Paul Share this post Link to post Share on other sites
