banker
Mitsubishi / Omron
13 posts in this topic
Hi I normaly use Omron PLC but now i have to use a Mitsubishi PLC. For this project size, I normaly will use a omron CJ1M CPU 13 With integrated Ethernet. What Mitsi PLC will match this omron plc.? Banker
It will be easier if you give us the specs of the omron!
Spec: 13 PID 16 AI 16 AO 64 Di 32 DO Banker
what do you need ethernet port for? what scan time you can live with?
Ethernet port for programming /HMI. Scantime is not importend, 10-30 msec.
FX3U has the I/O capacity and modules needed to meet this spec (not sure about number of PIDs), but it looks like it may have a problem with 5V rail (short of some 100mA or so). at this moment i'd say go with Q.
I would go entry level Q series, like Q00UJ. Or even Q00. Q00UJ is a PLC, power supply, and 5 slot rack. You would most likely need one extension rack to accomodate all the cards. Q64AD is 4 volt/curr inputs, but Q68ADI or Q68ADV can do 8 inputs per card. There are 16, 32, and 64 point I/O modules. But it can be done with an FX3U-64. Add 2 16-pt input cards, as the base is 32 in and 32 out. FX2N-8AD module offers 8 analog inputs, so 2 of these. You can use the FX3U-4DA for analog outputs (4 of these), and you will most likely need an FX3U-1PSU-5V before the analog outputs for bus power issues.
Q00J-program capacity 8K.It's small.
I have not used this model in a while (or much) - but I seem to think the capacity was 16K
Hi all thanks for the info. I will take a look at the Q serie PLC. Banker
Q00J was 8K. Q00UJ is 10k. And that's actually quite a bit of memory when compared to a small PLC like the CJ1 CPU 13. I've controlled tons of complete projects in under 8k.
8K.See screenshot
That screenshot is for a Q00J not a Q00UJ Edited by Gambit
