Posted 14 Dec 2005 on the micrologix 1200 ther are 2 trim pots one side of the chanel 0 comunicatin port did some one now the funcion of this trim pots? Share this post Link to post Share on other sites
Posted 14 Dec 2005 From the Allen Bradley Manual page 85.. http://literature.rockwellautomation.com/i...um001_-en-p.pdf The processor has two trimming potentiometers (trim pots) which allow modification of data within the controller. Adjustments to the trim pots change the value in the corresponding Trim Pot Information (TPI) register. The data value of each trim pot can be used throughout the control program as timer, counter, or analog presets depending upon the requirements of the application. Share this post Link to post Share on other sites
Posted 14 Dec 2005 There are better ways to manipulate data aren't there? I'm curious if anyone has found a good application for using this feature Share this post Link to post Share on other sites
Posted 14 Dec 2005 I have never used them. I don't feel you should have to go into a control panel to adjust anything Share this post Link to post Share on other sites
Posted 14 Dec 2005 The only time I have used them was for working out some of the bugs in temperature control logic. I used a SCP (scale with parameters) to scale TPI:0, POT0, to the same as the input range on my thermocouple. With the help of a move function I was able to control that part of the logic without the thermocouple. I have mostly used it on the bench as a simulated input, but never out on a working machine. Share this post Link to post Share on other sites
