Posted 6 May 2020 Hi I noticed problem that I cannot use INI inside FB. It supposed to look like attachment. Whatever parameters I set CXP inidcate error Share this post Link to post Share on other sites
Posted 6 May 2020 (edited) You may have to assign the PV word to an address. Create an internal address on the function block and assign that to the PV. To expand on this, "0" is actually an address in a program it refers to CIO0. So although you are not using the PV on your configuration you will still need to assign it to a memory address. Edited 6 May 2020 by chelton Share this post Link to post Share on other sites
Posted 6 May 2020 24 minutes ago, chelton said: You may have to assign the PV word to an address. Create an internal address on the function block and assign that to the PV Yes, using real addresses inside a function block ruins its portability. Share this post Link to post Share on other sites
Posted 7 May 2020 (edited) Edited 7 May 2020 by Sergei Troizky Share this post Link to post Share on other sites
