Posted 22 Feb 2017 I am just getting started with CX One Designer and I am wondering if anybody can tell me if it is possible to change the font and border colour to indicate state for a multi state input. The system I am monitoring has 7 different states and the customer has asked for a colour coded label to indicate the state of the system. i.e. red = bad, green = good, amber = warning etc. Any help is appreciated. Share this post Link to post Share on other sites
Posted 23 Feb 2017 From reading the brief CX-Designer manual I get assume this type of action is possible via a macro. Can anyone provide any sort of guide on using macros or can provide an example of one which might solve the problem. What I am hoping for is based on an integer value between 1-7 the background colour of a label and the font itself will change colour to match the above example. Share this post Link to post Share on other sites
Posted 23 Feb 2017 You could consider a word lamp instead. Just an idea, that doesn't require script. Share this post Link to post Share on other sites
Posted 23 Feb 2017 32 minutes ago, Crossbow said: You could consider a word lamp instead. Just an idea, that doesn't require script. Thanks for your reply. It looks like I may have to do more that just replace labels depending on I/O values so getting familiar with scripts may be required. Do you have any links to a guide to using scripts in CX designer at all? Share this post Link to post Share on other sites
Posted 23 Feb 2017 Try the examples found in the last post in this topic: http://forums.mrplc.com/index.php?/topic/31941-nummural-input-box/#comment-150227 Share this post Link to post Share on other sites
Posted 25 Feb 2017 Use a Label. In the Properties of the Label on the General tab, check 'Use as a Message Display'. In the Message tab, choose the number of statuses and a custom font for each of them. Share this post Link to post Share on other sites
