Posted 20 Aug 2008 I have ethernet connection on my plcs working and I need to get information from omron plc's to PC's and siemens plcs. Anyone has good ideas how to do it? I was thinking about using OPC server. I just need to transfer few simple numeric values. Any good OPC servers who can connect both S7 and CJ1-? (preferrably free so I could just test if it works). Share this post Link to post Share on other sites
Posted 20 Aug 2008 Have a look at Kepware: http://www.kepware.com/Products/kepserverex_features.html Demo runs for 2hrs and supports all major PLC brands. Excellent help on setting up comms and good tag database editing. I have used it quite a lot and am very satisfied. Share this post Link to post Share on other sites
Posted 20 Aug 2008 Also suggest you take a look at InGear. http://www.ingeardrivers.com/omron_opc_ser..._opc_server.htm Share this post Link to post Share on other sites
Posted 21 Aug 2008 Hi, Is this occasionally, or as part of your control system? I'm not sure I would add a PC, Windows, and 2 OPC drivers inside a critical system... Can anyone else thing of good alternatives? Howabout: - Use a Serial link... maybe with Modbus or similar? - Using Profibus/ProfiNet as a 'datalink' network? - Use some kind of gateway device? The Omron NS allows reading and writing to Omron and Siemens (although seems like overkill!) Anything else simliar? Anyone got more ideas like this? Bertie Share this post Link to post Share on other sites
Posted 26 Aug 2008 I would go for the profibus. The siemens plc can be master, then all you need is the PRT21 slave card. Very easy to use. Share this post Link to post Share on other sites
