Controllogix 5000
  • Please log in to reply
39 replies to this topic
#1 hipoint2
hipoint2
    Sparky
  • MrPLC Member
  • PipPipPip
  • 27 posts
  • Country:United States
    United States
Posted 31 March 2006 - 02:22 PM
I am new to this control logix stuff so bare with me. I am trying to use a BSL instruction to test some outputs, but my problem is that this instruction HAS to use a double integer. So what I used to do in the old SLC and PLC would be set a bit in a integer and use a timer to keep shifting it left, and just use a MOV instruction to move the integer to the output word. It was easy to move a 16 bit integer word to a 16 bit output word. But now with this 32 bit stuff it gets a little more complicated. I started off using the MOV instruction to the output word then after the 16 bit I had to put in a xic to ote 16 more times to get the higher part of the word. Anybody got any good suggestions? :shrug:
#2 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 31 March 2006 - 02:29 PM
I'm not sure I am following you, but I think you need to put a DINT in your BSL that you MOV to you output instead of and INT
#3 hipoint2
hipoint2
    Sparky
  • MrPLC Member
  • PipPipPip
  • 27 posts
    United States
Posted 31 March 2006 - 02:40 PM
I know you have to put a DINT in the BSL or when you compile it it will error out. But every time the timer gets done the BSL rung goes true which would shift the bit over one. So the next rung has the MOV which moves the entire BSL destination word right to the Local output word which is only a INT. So after bit 15 in the BSL dest. word is bit 16 but the local output word only goes to 15. Its a 16 bit output card. Make anymore sense or did I do even worse?
#4 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 31 March 2006 - 02:46 PM
Can you post a screen capture of your rung or post your file? I think I am misunderstanding you :shrug:
All I/O modules I can think of have 32 points even if there are only 8 physical outputs
#5 hipoint2
hipoint2
    Sparky
  • MrPLC Member
  • PipPipPip
  • 27 posts
    United States
Let me try this out. How do you do a screen capture?
  • Attached File  help.ACD   94.88KB   316 downloads
#6 Ken Moore
Ken Moore
    Principal Specialist
  • MrPLC Admin
  • 1711 posts
  • Gender:Male
    United States
Posted 31 March 2006 - 02:49 PM
I'm no CLX expert, but could you not use a timer, a counter and indirect addressing instead?
Timer done bit, indexes a counter, the counter value is used for the indirect address. Then you could limit the counter to 0-15.
Just a thought
#7 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 31 March 2006 - 03:19 PM
Can you post it with you tags in the browser. I think your data types might be the problem
Oh wait. Are you trying to get the upper half of your DINT into slot 4?
Is this what you are looking for. The lower half of test2 will go into slot 3. The upper half will go into slot 4
Edited by TWControls, 31 March 2006 - 03:16 PM.
#8 Smoke
Smoke
    Automation Controls
  • MrPLC Member
  • PipPipPip
  • 188 posts
    United States
Posted 31 March 2006 - 04:18 PM
You could move a zero into Bays_Test_Control.POS after it is EQ to 16
With a 15 in your length in the BSL you will be moving 15 BOOL's at a time.
You could put a 2 the length then skip a BOOL @ "test2"
Or try putting 32768 in the length of the Control "Bays_Test_Control.LEN"
This might stop the setps at BOOL 15. Im not sure though
Edited by Smoke, 31 March 2006 - 05:07 PM.
No trees were knowingly harmed in any way during the production and transmission of this message. A rather large number of electrons were somewhat inconvenienced however.
#9 BobLfoot
BobLfoot
    The Wizard
  • MrPLC Admin
  • 3167 posts
  • Gender:Male
    United States
Posted 31 March 2006 - 07:34 PM
The simplest sway to screen capture is to use the Print Screen button on your keyboard. This Copies the Screen you are looking at into the windows clipboard. next open Paint and paste the clipboard to a new paint file. Hint when you save select type .jpg as .bmp is much larger and just wastes space.
How about replacing your xic to ote with the following.
SOR GRT MY_DINT 16#00FF MOV 1 MY_DINT EOR
This will move a 1 into your DINT any time a bit beyond 15 is true and restart your test of bits 0 thru 15.
BobLfoot
"Poor Planning on your part does not a crisis on my part make"
#10 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 01 April 2006 - 06:46 AM
I have not tested this code but try this. Every two seconds the BSL will shift. The upper half of the BSL is distributed to slot 4 using the BTD.
The only problem I see is currently your BSL length is 15. I think you want to change it to 32. Otherwise you will only see bits 0-14 change and only outputs 0-14 of slot 3 will be affected
And I left the unlatch of the BaysOpen in there thought I'm not sure you want that
Edited by TWControls, 01 April 2006 - 06:47 AM.
#11 Smoke
Smoke
    Automation Controls
  • MrPLC Member
  • PipPipPip
  • 188 posts
    United States
Posted 01 April 2006 - 07:49 AM
Bob how does the length work in the control tag.
#12 BobLfoot
BobLfoot
    The Wizard
  • MrPLC Admin
  • 3167 posts
  • Gender:Male
    United States
Posted 01 April 2006 - 08:41 AM
I believe that length in the BSl dictates the number of bits to shift and in the BTD it indicates the number of source bits to copy to the destination.
BobLfoot
#13 Smoke
Smoke
    Automation Controls
  • MrPLC Member
  • PipPipPip
  • 188 posts
    United States
Posted 01 April 2006 - 09:13 AM
I'm not refering to the length in the BSL but in the CONTROL tag itself.
By the way I cant get the Emulator to work. I selected the Emulator controler and a vitural backplane in Linx
what else do I need?
Edited by Smoke, 01 April 2006 - 09:17 AM.
#14 BobLfoot
BobLfoot
    The Wizard
  • MrPLC Admin
  • 3167 posts
  • Gender:Male
    United States
Posted 01 April 2006 - 09:49 AM
BaysTestControl.Len is where the length from the BSL command is stored. BaysTestControl is the data structure which the BSL uses to accomplish the shift.
BobLfoot
#15 hipoint2
hipoint2
    Sparky
  • MrPLC Member
  • PipPipPip
  • 27 posts
    United States
Posted 05 April 2006 - 01:49 PM
Thanks TW that is what I was looking for. Instead of a MOV using a BTD.
Thanks again guys!
#16 mellis
mellis
    Sparky
  • MrPLC Member
  • PipPipPip
  • 60 posts
    United States
Posted 05 April 2006 - 04:34 PM
Just a word of caution about the BTD instruction.
It can generate minor processor faults in a way that is not obvious. If you move a value from a DINT into an INT using a BTD and bit 15 is ON, you get a minor processor fault. It has to do with the way the ControlLogix does type conversions. For whatever reason, it trips over the fact that the value changes from a positive to a negative as a result of the BTD even though the BTD is an instruction intended to manipulate on the bit level.
In your case, I believe you will be OK. As TW pointed out, all the digital I/O modules I've used have a DINT for the output data regardless of the actual point count on the module.
For a more general solution of the problem of moving the bits from a DINT into two INTS, the COP or CPS instructions do a nice job. "COP My_DINT My_INTarray[0] 2" will split a DINT into two INTs that you can then MOV as needed without any annoying minor faults.
Just one of those things that has bit me before.
#17 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 06 April 2006 - 05:38 AM
I have never ran into this and frequently BTD Dints into Ints. Can you post an example so I can play with it?
#18 mellis
mellis
    Sparky
  • MrPLC Member
  • PipPipPip
  • 60 posts
    United States
Posted 06 April 2006 - 10:24 AM
TW,
Try this. I don't have a CLX setup in the office right now to check, but this is the situation I ran into in the past. If I can get some time later I'll double check it too.
BTD MyDINT 0 MyINT 0 16
When MyDINT is greater than 32767, you should see a minor fault.
The plant I was working at the time was using version 11 firmware, so it's possible Rockwell changed it in later versions.
#19 mellis
mellis
    Sparky
  • MrPLC Member
  • PipPipPip
  • 60 posts
    United States
Posted 06 April 2006 - 12:24 PM
TW,
Update
I found someone in the office with a version 12 processor and checked it. It definitely causes a minor fault in version 12 too.
In my earlier post I said that a value greater than 32768 would cause a fault. That's not 100% accurate. What is actually the trigger is bit 15 ON. A value from 32768 to 65535 in a DINT will have bit 15 ON and that was the range I was interested in since I was only BTDing 16 bits.
#20 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 06 April 2006 - 02:39 PM
I can't seem to replicate your problem. Below is what I setup and no faults. Am I understanding correctly?
#21 BobLfoot
BobLfoot
    The Wizard
  • MrPLC Admin
  • 3167 posts
  • Gender:Male
    United States
Posted 06 April 2006 - 03:32 PM
TW if you then use your INt as the present of a timer or the process value of a PID you'll get an error.
BobLfoot
#22 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 06 April 2006 - 03:36 PM
I understand that, but mellis is saying with a BTD. I think someone lost me. :doh:
#23 mellis
mellis
    Sparky
  • MrPLC Member
  • PipPipPip
  • 60 posts
    United States
Posted 06 April 2006 - 06:41 PM
TW,
Your example looks just like mine.
Are you checking under Controller Properties, Minor Faults tab? This isn't going to turn the "Online" box red and say "Fault". It's just going to log a minor fault each time it happens. It doesn't halt the processor, just wastes processor time.
What firmware version are you running? I still haven't checked under 13 or 15 yet. But I'm betting they are the same.
Now like Bob says, stuffing a negative number into a timer preset will get you a major fault. But that's a different story.
#24 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 06 April 2006 - 06:46 PM
Yes, checked the minor faults tab. No fault. I tried on version 15 but I'm pretty sure that I have been doing that same thing since version 10 or so.
Can you post a sample program that is doing it? May be I'm missing something you are saying.
#25 mellis
mellis
    Sparky
  • MrPLC Member
  • PipPipPip
  • 60 posts
    United States
Posted 06 April 2006 - 07:24 PM
TW,
I don't think it's the program. It's just one instruction. And I can see by the data that the source is a DINT and the dest is an INT. I can also verify that it is the same bit pattern in both tags. Can't imagine how there could be a problem there.
I'll see if I can flash the processor I have to ver 15. The guy who is using it will probably not like that idea much <eg>.
The only other thing I can think of is processor model? I've seen this in L1 processors and the one I checked today is a L55. What are you using?
I really didn't expect this to turn into a discussion, but now I am really curious as what exactly is going on here.
This is the kind of question the Rockwell forum was actually pretty good at. Someone like Ron Bliss would pop up with a definitive answer. I'm going to miss that.
#26 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 06 April 2006 - 07:40 PM
I would not be suprised if they were not here somewhere.
I tried it on an L55. I'm not doubting you but apparently I'm just not following you. There is not chance that your destination bit was greater than zero or you length was greater than 16 is there. Or am I way out in left field :doh:
#27 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 06 April 2006 - 07:55 PM
I've got L1s and L55s doing BTDs in the same manner. Thats why I am confused. I may need to put something in mine to keep this from happening. But I got to make them do it first, thats why I'm trying to make sure I fully understand
#28 Contr_Conn
Contr_Conn
    Sparky
  • MrPLC Member
  • PipPipPip
  • 426 posts
    United States
Posted 06 April 2006 - 07:58 PM
I did not follow this discussion from beginning, but as far as I know in every version of logix every time you put into the integer tag a value with bit 15 set, it will generate minor fault "Overflow". You may just ignore it or reset it.
It's always recomended to use DINT for all calculations including 16 bit processing.
#29 TWControls
TWControls
    Industrial Sorcerer
  • MrPLC Admin
  • 4543 posts
  • Gender:Male
    United States
Posted 06 April 2006 - 08:05 PM
Ok, guess I need to hunt and figure out how I have never managed to set bit 15 :doh:
#30 Contr_Conn
Contr_Conn
    Sparky
  • MrPLC Member
  • PipPipPip
  • 426 posts
    United States
Posted 06 April 2006 - 08:31 PM
Actually I was not correct:
If you are using BTD, no overflow will be generated as this is just a bit pattern.
Same with COP instruction, as it copies a bit pattern without checking a value.
But if you are using MOV <DINT> to <INT> and DINT >32767, then overflow will be set, but result will be the same as BTD
(Type 04) Program Fault
(Code 04) Arithmetic overflow. Result of an arithmetic instruction out of range.
Task: MainTask
Program: MainProgram
Routine: MainRoutine
Here is definition:
Overflow is set if the value you are storing cannot fit into the destination.
Either the value is greater than the maximum value for the destination
or the value is less than the minimum value for the destination.
Edited by Contr_Conn, 06 April 2006 - 08:31 PM.
