AndrejP
Omron CJ2M and CP1L as I/O expansion over ethernet
3 posts in this topic
Hello.
What is the best option using TCP/UDP communication to use CP1L-EM40 as SLAVE / IO Expansion?
For MASTER I’m using CJ2M-CPU31.
Since now I’ve used FINS _CPU010_SendData and _CPU011_ReceiveData function blocks.
The problem is, that I’m communicating with 6 slave IO units and to read/write all 6 units it takes up to 1 – 2 seconds.
I’ve tried Ethernet/IP protocol but CP1L units doesn’t support this protocol.
Is there some kind of different TCP/UDP protocol which is faster than FINS?
In older days you could use PC Link but this protocol is for RS232 / RS485 comm.
I know I could use CP1W-EIP61 but I don't have this adapter and I can't afford to buy one
Thanks.
Edited by AndrejP
Better option would be NX-Series IO with an EtherNet/IP coupler talking EIP to the CJ.
Crossbow is right
If you need a deterministic update, using a CP1L for RemoteIO is not the way to go.
saying that, you should be able to get updates from a CP1L using FINS within 500ms. (I can probably validate this)
I wouldn’t be using those FBs if there more than 1x instance required..
