vtripathi
data registers Data register over flow
5 posts in this topic
Hi,
data registers are getting full, because of extremely high speed pulsing
is there any way , if the data value in register goes above the capacity of 32 bit register, it automatically attaches itself to next set of data registers
so lets say if data was written in D10,D11
Upon reaching the limit, it goes to D10, D11, D12, D13
please share if there is an alternate way to do this
I don't fully understand what you want to do but look at Z registers.
Psudo codeo follows...
Initialise Z0 to 0
Using 5 double registers
IF Z0 = 20 THEN Z0= 0;
Something that adds to D10Z0;
IF D10Z0 > (limit)THEN Z0 = Z0+2;
Total = D10+D12+D14+D16+D18; but you are back to the initial problem of representation of a value greater than a double word/Dint.
Enter that in your code of choice and you should be able to work something out.
Alternatives,
1.used cascading counters.
C1 counts to say 1000,
C1 done then reset C1, increment C2.
C2 counts to say 1000 but represents 1,000 to 999,000
Repeat for as many counters as necessary.
Total = C1 count + C2 count x1000+...etc
2. Counter example but use registers instead of counters. A mix of the original solution and 1.
3.Use real/float datatype.
4. Pay me and I'll do it for you :)
1 person likes this
Hi
please find the code attached
i have 2 pole motor, which runs approximately at 3000 rpm, and encoder is 2000ppr
Frequency is approx 100 khz, Counting is not a problem, its just holding the values
32 bit register can hold 2 billion bits, and at 100khz , my data register will be filled in 2000 sec, i need it to operate for much longer time than that
so my quest is if it reaches lets say 1 billion bits, it automatically attaches it to adjacent register
Explaining it in simple ways would be, i have created dataflow as a water flow analogy
i will try with index registers, since its used for positioning, i will still be required to add the values, and then start decrementing them in reverse order
i am still trying to get my head around Last in first out command and shifting registers, may be that can work
thanks
Best Regards,
Vib
Encodercontrol.pdf
Encodercontrol1.pdf
Sounds like you need "register extension" to make  a 64-bit register.  If you are doing the adding in code, you would use your PLC's arithmetic carry bit to indicate when to add one to the 2nd register.  But if the register is external, (like an external digital encoder), you will need to monitor changes in the top two bits of the register to decide when to overflow/underflow into the 2nd register.  The pythonish pseudocode would be like this, where E is the external encoder, and V0 and V1 are the two 32bit registers composing the 64-bit result:
# Catch forward rollover
if V0.30 and V0.31 and not E.30 and not E.31:
    V1 += 1
# Catch reverse rollover
if E.30 and E.31 and not V0.30 and not V0.31:
    V1 -= 1
# Copy low 32 bits
V0 = E
Thanks, i will try that,
best regards,
Vib
