Posted Tuesday at 3:59 PM how to program a thumb wheel switch with delta plc using isp sowftware Share this post Link to post Share on other sites
Posted Wednesday at 4:16 PM (edited) First you have to find out the thumbwheel switch output’s coding system (binary, decimal, hexadecimal). Then you have to find the output’s polarity (common anode or common cathode) in order to connect it proper to the PLC’s inputs. Each digit of the thumbwheel switch has 4 outputs. So you have to use inputs X0-X3 of the PLC for the first digit, X4-X7 for the second digit etc. For the first digit (if the thumbwheel switch has binary outputs) you may use BIN instruction in format with Kn value to modify the input values: LD M1000 BIN K1X0 D0 The instructions above will continuously convert the states of the X0-X3 inputs and store the result in D0. So D0 will contain the first digit of the thumbwheel switch (if the first digit of the switch is 1, the value in D0 will be 1 as well). The situation for the other digits will be similarly. Edited Wednesday at 4:18 PM by IvanBratanov Share this post Link to post Share on other sites
