Posted 12 Apr 2005 I am looking for the pinout of the Cable to interface the Pannel mate 1000 to a PC for uploading /downloading of programs Share this post Link to post Share on other sites
Posted 12 Apr 2005 It is a standard serial cable. Should be able to find the pinouts almost anywhere. Share this post Link to post Share on other sites
Posted 12 Apr 2005 Ken, It is a straight or NULL? I assume you meant NULL with a 2-3 ad 3-2 cross over correct? PS: bjclem, I like to go to this place: http://www.hardwarebook.net/ Has all the pin outs and stuff for everything from DB-9 to DB-9, DB-9 to DB-25 etc,etc... Excellent reference to keep bookmarked. Share this post Link to post Share on other sites
Posted 13 Apr 2005 I'm pretty sure its the straight thru (verses the Null which gets you to the PLC's com1). Share this post Link to post Share on other sites
Posted 16 Nov 2005 Panel Mate does not use the standard pins 2 and 3, as in RS-232C although it is null modem communication. I found the pin out on the book that came with the software to program the HMI. If you have the book you might check there. Share this post Link to post Share on other sites
