Posted 21 Feb 2022 Hi. I use the email block on few of our NJ101-9020 controllers to send out daily reports or any status updates. Recently the PLC's started an unknown issue and fails to send email out anymore. I use the Mail_Send function block from Omron to send emails. The only Error ID i can get is 2005, with status being "Connection to SMTP" failed. Looking at the troubleshooting guide, i cannot find anything to do with error id 2005, in fact its missing. There is 2004 and 2006 but no 2005. I've tried all the obvious thing like, power cycle, redownload the whole project, create a new instance of Mail_Send function block etc. Nothing seems to have fixed this unknown issue. Our IT department did a full check on their side and nothing seems to be out of order. I can still remote into the PLC, so i dont know what exactly is the problem. Has anyone came across this error ID before? Any ideas why this might have been happening? It was working well until few weeks ago and nothing changed and this suddenly started. Any input is really appreciated. Thank you. Share this post Link to post Share on other sites
Posted 22 Feb 2022 Probably an issue at the mail server end. Did your mail server change? Someone set a password on the server? Perhaps an update on a router or firewall? Share this post Link to post Share on other sites
Posted 22 Feb 2022 Hi @Crossbow Thank you so much for the reply. There are no changes to the mail server nor there was any update on the router or firewall. I've confirmed this with our IT department. We have other PLC's, same model and executing almost exactly the same operation on other machines sending emails without failure. It so confusing that the error ID 2005 is not found anywhere. Share this post Link to post Share on other sites
Posted 22 Feb 2022 If no changes were made to the network or the mail server, and no changes were made to the PLC's IP or subnet mask, then there is no reason it should not still be working. Something has changed, you need to figure out exactly what. If it was working, it would not stop unless something has changed. If the function block works in other PLCs, check what differences there may be in the configuration. Share this post Link to post Share on other sites
Posted 24 Feb 2022 @CrossbowThank you for the response. But unfortunately neither i or my colleagues can find any difference in the configuration in the PLC's. Its quite random and we are currently on talk with Omron to find a solution. Like i said, as this error code "2005" is unknown, its a bit a hard to troubleshoot as we don't know what we are looking for. Thanks for taking time to help me out, but at this point i think i will have to wait for an output from the manufacturer. I was hoping i would find someone here who might have faced similar issue and can shed some light into the situation. Thank you. Share this post Link to post Share on other sites
Posted 24 Feb 2022 4 hours ago, AswinJose said: I was hoping i would find someone here who might have faced similar issue and can shed some light into the situation. Please share when you get it figured out. For future clones of you with this problem. (: Share this post Link to post Share on other sites
Posted 5 Mar 2022 Mai_Send cannot connect to a SMPT server using SSL/TLS encryption. More and more servers don't accept mails without encryption anymore. So maybe you are sending the mail to a server that requires encryption now? Share this post Link to post Share on other sites
