M302015
Omron CP1L-EM Wonderware Intouch Driver?
7 posts in this topic
Hi,
I may need your help. What particular Wonderware Intouch driver needed to hook with Omron CP1L-EM ?
Thanks for your help.
Regards,
Jay :)
If you use a serial connection it will be Host Link.
If you use an Ethernet connection it will be FINS.
Thanks IORack but what I'm asking is for the SCADA driver. Ive read its DASOMFINSENET but CP1L or at least CP series is not on the list.
Kindly help.
Judging from the list of PLCs in your picture, I'd say the driver you are using is very old. What version of Intouch our you using?
Hi,
The Intouch version is 12.
I would appreciate for your advice. Or, can you please send me a link to download of the latest DASOMFINSENET and I'll check.
Thanks.
Regards,
Joel
Why don't you try Intouch support?
I haven't used it in a while. The support used to be regional.
Use CJ1.
All that does is assist in the available IO memory (or similar) & where things are stored.
as an FYI, DASOMFINSEnet has been replaced by OMRONFINS, which is a shame as DASOMFINSEnet was a far superior version.!
DASOMFINSEnet will still run though, but I’ve run into OS issues with later versions of windoze.
