Posted 20 January I got a new cpm2a and installed cx one (programmer) on my dell XP and tried connecting it but failed. I’m using the peripheral port (serial to usb (cif02)) and also made sure my drivers read this cable correctly but when open my cx programmer I choose cpm2a* and when try changing the network type to the USB port, it doesn’t show up at all. Idk what I’m doing wrong. Please help Share this post Link to post Share on other sites
Posted 20 January @Nkiragga If you use Serial to USB cable you need to select communicate with COM Port of your cable. Share this post Link to post Share on other sites
Posted 20 January USB port in CX-Programming is only for PLCs with a USB port on board. You are using a serial cable with a USB converter, it will show up on your PC as a COM port. Share this post Link to post Share on other sites
Posted 20 January I have set up my com port but for some reason now it has a yellow triangle with an exclamation mark. And I have updated the driver for this com but nothing. Still stays yellowed out Share this post Link to post Share on other sites
Posted 21 January Sounds like Windows doesn't like your USB to serial adapter or your drivers are in error. Share this post Link to post Share on other sites
Posted 22 January (edited) Thankyou guys. Really appreciate it. I was able to connect it via serial instead but now the PLC is stuck with an error red light. I can’t find a way thru the manual on how to remove it from the get go before starting to program what I’ve noticed is that as soon as I give power to the PLC even if I haven’t connected it to the PC thru the serial cable I’m using, the error (red light) is already showing Edited 22 January by Nkiragga Share this post Link to post Share on other sites
Posted 22 January Sounds like an invalid program or a hardware problem. Share this post Link to post Share on other sites
Posted 24 January On 1/22/2021 at 1:36 PM, Nkiragga said: Thankyou guys. Really appreciate it. I was able to connect it via serial instead but now the PLC is stuck with an error red light. I can’t find a way thru the manual on how to remove it from the get go before starting to program what I’ve noticed is that as soon as I give power to the PLC even if I haven’t connected it to the PC thru the serial cable I’m using, the error (red light) is already showing You should check alarm log that which alarm occurs. 1 person likes this Share this post Link to post Share on other sites
