Jqd84983
Omron Peripheral Port CJ1M-22 PLC for OPC Data
8 posts in this topic
Hi,
I am very inexperienced with Omron hardware so apologies if this is a daft question.
I am trying to use Kepware to retrieve data from a CJ1M-22 PLC via the peripheral port using RS-232 and the Toolbus Kepware Driver. The RS-232 is provided by a Brainbox ES-246 Ethernet to RS-232 convertor.
I have no problem accessing the PLC using this peripheral port via the programming lead but I wanted to know if anyone had successfully pulled PLC data through this port?
Many thanks
John
1 person likes this
The peripheral port in the CJs uses ToolBus protocol. That being said, you can get a CS1W-CN118 cable to convert it to RS232C 9 pin DE.
Is the built in serial port already being used?
You could also add a CJ1W-SCU21 for 2 additional serial ports.
Edited by IO_Rack
It sounds like his hardware is good as he says he can upload / download through the port using CXP.  If Kepware's Toolbus driver works, then it should be a matter of configuring Kepware to get the data that you need.  Maybe someone in here is fluent with Kepware.
Thanks for the reply.
I have purchased a CS1W-CN118 converter (see picture) as the built in serial port is being used to drive an HMI. There is a CJ1W-SCU21 already fitted but I was reluctant to mess around with that unit as it is a validated pharmaceutical production machine and would give me issues in re-validation potentially by having to change the code to alter the port configurations. All i have currently done is chnage the Peripheral Port to ToolBus protocol.
Kepware is transmitting the bytes in Toolbus but I am getting a reply from the Brainbox unit constantly of FF FD 03 FF FD 00 FF FD 2C when the Kepware Toolbus driver transmits AC 01 to the device. I believe this is a Telnet code but I don't know what this is telling me currently. I have proved it is coming from the Brainbox by disconnecting from the PLC and attaching a Laptop to read the data using Terminal software. I can read the AC 01 value but still get the 9 bytes returned above so I am a little stuck at the moment. I am awaiting some tech support from BrainBox.
Cheers
John
I assumed a connection with the CS1W-CN226 for programming purposes only. I also assumed the CN226 would not do Host Link. (I was wrong). Either way that doesn't matter because:
I didn't realize there was a third party Toolbus driver available. I thought Toolbus was proprietary to Omron.
If I'm not mistaken (and I may be), the CS1W-CN118 will not communicate via Toolbus without an additional converter cable.
Mr_PLC_Toolbus_Cables.thumb.JPG.19c412b4
Edited by IO_Rack
1 person likes this
Update
After more work I realised that the Telnet error code ( FF FD 03 FF FD 00 FF FD 2C) was returned by the Brainbox unit. I therefore changed the configuration of the Brainbox to Raw TCP and this stopped the issue. On reconnecting to the Peripheral Port I am now receiving a response from the PLC of 00 (Null) if using the Toolbus protocol or Host Link protocol in Kepware.
Do you think there is a setting somewhere in the PLC config (similar to Siemens) that has to ticked to allow Data access by external sources? I have scanned the PLC config and nothing obvious jumped out.
Everyone for Info I took the advice from the Kepware help files and purchased a CS1W-CN226 cable from the Brainbox RS232 to Ethernet converter to the Peripheral port. This solved the problem with Data flow and I started to get data returned immediately.
Glad you got it working and thank you for your response!
Which driver are you using in Kepware? (ToolBus or Host Link)
