Posted 23 Apr 2020 Hi all! We have a problem with a Mitsubishi system. After switch off the machine in home position and back on, it resets the servo encoder value to 0. I checked the servo parameters, and the Absolute encoder is enabled, the ext. battery is ok and no zero reseting in the program ( I think...). Is there a parameter I should check or some setting in the intelligent module? The system consists Q01CPU, QD77MS2 im., J4 200B amp with 6v battery, and HG-SR152 motor. Share this post Link to post Share on other sites
Posted 23 Apr 2020 (edited) But isn't the home position 0??? By default this would be 0 Edited 23 Apr 2020 by Gambit Share this post Link to post Share on other sites
Posted 23 Apr 2020 No, the home position is about 270 degrees by program setting. This value is overwritten. Share this post Link to post Share on other sites
Posted 26 Apr 2020 On 4/23/2020 at 7:45 PM, Gman1 said: Hi all! We have a problem with a Mitsubishi system. After switch off the machine in home position and back on, it resets the servo encoder value to 0. I checked the servo parameters, and the Absolute encoder is enabled, the ext. battery is ok and no zero reseting in the program ( I think...). Is there a parameter I should check or some setting in the intelligent module? The system consists Q01CPU, QD77MS2 im., J4 200B amp with 6v battery, and HG-SR152 motor. Hi, Did the HPR is completed sucessfully .? Share this post Link to post Share on other sites
Posted 26 Apr 2020 Gman1, When you install the battery for the first time, you should get AL.25 (abs position loss) after powering on the drive with the motor properly connected. This happened? After that you should turn off an on again and the alarm should disappear. Then you must perform OPR (home position return). If the above didn't happen, your drive is missing the absolute position detection parameter to be enabled or you have some problems with your driver/QD77MS. BR, Thiago Share this post Link to post Share on other sites
Posted 5 Jun 2020 (edited) Hi everyone! The problem has been fixed! It was the servo amp. battery. The old one was 6.1V the new one is 6.4V. After the replacement, everything was fine. There was no error message and the battery seemed fine. So that 0.3V difference was the guilty :) Edited 5 Jun 2020 by Gman1 Share this post Link to post Share on other sites
