udhaya
Communication between Proface HMI and Mitsubishi FX2n plc
4 posts in this topic
Hi All,
I'm facing communication problem in Proface GC 4401w with Fx2n plc (Via Option board FX2N-232-BD)
I had attached the pin details that i had used,
baud rate and connection parameters of PLC option board i had changed by moving values to data memory D8120, but still no result
please help
Thanks in advance
You do not have to use D8120 you can set the communication settings in de PLC parameters in GX Works
Dear All
You open GX-Work or GX-Developer and goes to Parameter setting as show on image
thanku
DId your problem solved if yes then which settings u have applied?
