RSLinx OPC Data Logging, Trying to find a simple enough way to write .csv with RSLinx and OPC |
Nov 3 2009, 12:27 PM
Post
#1
Hi, I am New! ![]() Group: MrPLC Member Posts: 4 Joined: 2-November 09 Member No.: 39,883 Country:Ireland
Greetings all,
I am fairly new to the PLC world, having doing most of my work before hand using DCS's in massive projects. I am currently working with AB compactlogix for a small enough project, designing a test/simulation rig. I am trying to find a simple way to log streaming data into a flat file (i.e. a .csv file) at a rate of 100Hz. I know technically I can do so using trending, but that method will not really suit my needs. I have looked into OPC Data Logger, but cannot get it to connect to the RSLinx OPC server. (I am running RSLinx Classic Pro - Single node) I have been banging my head against the wall now for a weeks and am getting almost nowhere, and basically I am looking for suggestions as to the best way to get data logging capabilities for roughly 200 points with out over doing it (i.e. having to by way more software then i need). Thanks much, James |
Nov 3 2009, 01:58 PM
Post
#2
Hi, I am New! ![]() Group: MrPLC Member Posts: 2 Joined: 1-April 05 Member No.: 7,389 |
Greetings all, I am fairly new to the PLC world, having doing most of my work before hand using DCS's in massive projects. I am currently working with AB compactlogix for a small enough project, designing a test/simulation rig. I am trying to find a simple way to log streaming data into a flat file (i.e. a .csv file) at a rate of 100Hz. I know technically I can do so using trending, but that method will not really suit my needs. I have looked into OPC Data Logger, but cannot get it to connect to the RSLinx OPC server. (I am running RSLinx Classic Pro - Single node) I have been banging my head against the wall now for a weeks and am getting almost nowhere, and basically I am looking for suggestions as to the best way to get data logging capabilities for roughly 200 points with out over doing it (i.e. having to by way more software then i need). Thanks much, James The simplest (and cheapest) solution I found this summer was from these guys: http://www.opclogger.com/products.php The non-Pro version is only 70 bucks or so and does .csv data recording. The next version up supports MySQL and MS-SQL as well. Skeet |
Nov 3 2009, 02:08 PM
Post
#3
Hi, I am New! ![]() Group: MrPLC Member Posts: 3 Joined: 20-October 09 Member No.: 39,759 Country:Canada
Have you tried Matrikon Analytics? it's easy and connects to RSlinx perfectly... it won't hurt to try it. it's free for 30 days:
http://www.matrikonanalytics.com/products/excelreporter.aspx Wassim Daoud Global Solutions Architect MatrikonOPC Greetings all, I am fairly new to the PLC world, having doing most of my work before hand using DCS's in massive projects. I am currently working with AB compactlogix for a small enough project, designing a test/simulation rig. I am trying to find a simple way to log streaming data into a flat file (i.e. a .csv file) at a rate of 100Hz. I know technically I can do so using trending, but that method will not really suit my needs. I have looked into OPC Data Logger, but cannot get it to connect to the RSLinx OPC server. (I am running RSLinx Classic Pro - Single node) I have been banging my head against the wall now for a weeks and am getting almost nowhere, and basically I am looking for suggestions as to the best way to get data logging capabilities for roughly 200 points with out over doing it (i.e. having to by way more software then i need). Thanks much, James |
Nov 4 2009, 05:24 AM
Post
#4
Greetings all, I am fairly new to the PLC world, having doing most of my work before hand using DCS's in massive projects. I am currently working with AB compactlogix for a small enough project, designing a test/simulation rig. I am trying to find a simple way to log streaming data into a flat file (i.e. a .csv file) at a rate of 100Hz. I know technically I can do so using trending, but that method will not really suit my needs. I have looked into OPC Data Logger, but cannot get it to connect to the RSLinx OPC server. (I am running RSLinx Classic Pro - Single node) I have been banging my head against the wall now for a weeks and am getting almost nowhere, and basically I am looking for suggestions as to the best way to get data logging capabilities for roughly 200 points with out over doing it (i.e. having to by way more software then i need). Thanks much, James Thanks lads, I am going to go ahead and try out both and see which works better for myself. Cheers, James |
Nov 4 2009, 01:03 PM
Post
#5
![]() The Wizard Group: MrPLC Admin Posts: 2,556 Joined: 27-March 06 From: Southern Indiana Member No.: 19,234 Country:United States
Greetings all, I am fairly new to the PLC world, having doing most of my work before hand using DCS's in massive projects. I am currently working with AB compactlogix for a small enough project, designing a test/simulation rig. I am trying to find a simple way to log streaming data into a flat file (i.e. a .csv file) at a rate of 100Hz. I know technically I can do so using trending, but that method will not really suit my needs. I have looked into OPC Data Logger, but cannot get it to connect to the RSLinx OPC server. (I am running RSLinx Classic Pro - Single node) I have been banging my head against the wall now for a weeks and am getting almost nowhere, and basically I am looking for suggestions as to the best way to get data logging capabilities for roughly 200 points with out over doing it (i.e. having to by way more software then i need). Thanks much, James James - have you looked in the downloads section at the RSlinx Excel DDE example I posted there. With RSlinx Pro and Excel VBA you should be able to gather the data you are looking for to an excel spreadsheet and the save as a csv file. I'l plan on packing 32 or 64 Ints of data at a time and transferring the packet rather than trying real time transfer. network latency will kill you otherwise. -------------------- BobLfoot
"Poor Planning on your part does not a crisis on my part make" |
| Think this page or topic is awesome? Submit to: |
Lo-Fi Version | Time is now: 20th November 2009 - 09:28 PM |
