cpm1a ethernet
  • Please log in to reply
2 replies to this topic
#1 kcor
kcor
    Sparky
  • MrPLC Member
  • PipPipPip
  • 356 posts
  • Country:United States
    United States
Posted 06 February 2007 - 12:47 PM
Is there a good way to have ethernet access to a omron cpm1a plc and be able to go online and troubleshoot?
Have some equipment getting ready to go to Honduraus, and they have cpm1a plc's.
#2 gtsuport
gtsuport
    Omron Disty
  • MrPLC Member
  • PipPipPipPipPip
  • 884 posts
  • Interests:Omron Distributor Tech Support, 4-H Volunteer
    United States
Posted 06 February 2007 - 01:53 PM
About the only thing I can think of would be to use a CPM1-CIF01 (Comm adapter) and the CPM2-ETI-L1 Digi One Real Port Serial to Ethernet Unit.
This will basically allow you to set an IP address for the CPM1, CX-Programmer will connect to the Digi One device and translate the info serially to the CPM1.
There are similar devices available. This one is configured to work with Omron PLC's. It has specific firmware to handle HostLink comm. Do not try to update the firmware in the unit, it will stop working.
Omron has some in stock in Schaumburg. However, they cost more than the CPM1.
Hope this will help.
#3 TERdON
TERdON
    Sparky
  • MrPLC Member
  • PipPipPip
  • 179 posts
  • Country:Sweden
    Sweden
Posted 06 February 2007 - 04:14 PM
Instead of buying specialized converters you could use a generic serial device server (converts ethernet to serial, use a special driver in the programming computer to interface it).
Moxa does good stuff which I've used. The one I used was about $300, however it was a really flashy dual port one, with WLAN and all. A single port server with only Ethernet should be considerably cheaper.
