Posted 29 Apr 2019 Hello, Just asking a question. It is possible to communicate two plc ( CJ2M ) using cx integrator.? It is possible to exchange data between the two of them? Thank you, Share this post Link to post Share on other sites
Posted 29 Apr 2019 (edited) You can use either PLC Link or FINS Send / Recv to communicate between two PLCs. PLC Link would be serial, FINS either serial or Ethernet. CX Integrator is for setting up networks, Devicenet, etc. gtsuport Edited 29 Apr 2019 by gtsuport Share this post Link to post Share on other sites
Posted 29 Apr 2019 Simplest method! Don't need CX Integrator. http://forums.mrplc.com/index.php?/topic/36339-send-data-memory-from-plc-to-other-plc-with-cx-programmer/#comment-169499 Share this post Link to post Share on other sites
Posted 1 May 2019 Thank you for the replay, I am using ethernet connection. SEND and RECEIVE command is the only i should do. Am i right? There is no other setting in the plc to be set? Thanks in advance Share this post Link to post Share on other sites
