Spedley
PB32 bug
4 posts in this topic
Has anyone else encountered the bug in PanelBilder32 V3.80 where you can have an embeded variable with no tag and it lets you download it to a PanelView. I could not get the PanelView to reset, it kept coming up with Error 60 and did not show up in RSlynx (PV600 touch/keypad). Fortunatley I was able to get it to the Config screen and I could correct the problem from there. It was only a bit of development work but see if it verifies with no errors and then have a look at the states for Zones 1 to 8 on screen 4. QuickPRESS.PBA
I have never ran into that. Normally if you double click on the embeded variable it will pop up the configuration dialog but this one doesn't. How did you do it or can you replicate the problem?
I haven't checked the README on the patch, but there is a 3.81 patch for PB32 if you suspect a bug. If you're in support it's downloadable from you know where....
I've got version 3.82.00 build 413
