Posted 19 January Hi there! I'm trying to communicate a Weintek cMT2128X with a CP2EN via Ethernet. The thing is I'm getting 'No device response' messages every 2-3 seconds. They'are connected at some point because some values are updated, but the connection error keeps showing up. So far I've checked: - Comm. settings are okay in both sides - Wiring is good - Happens the same with a CJ2 CPU. - There are two arrays of 50 UINT each, I don't know if that's slowing things but that would surprise me... I've worked with Weintek HMIs before (communicating with different CPUs: LOGO!, CP1, CJ2...) and never had this problem. I just set the IP addresses and everything was working fine, so I guess I'm missing something. Hope you can throw some light at this! Thanks in advance Share this post Link to post Share on other sites
Posted 22 January Morning, If some values are updated and in the same time you get a "no plc response" message that means one or several tags on the displayed screen can't be read in the plc. It could be a wrong adress, outside range, bad type etc. So you have to carrefully check all your tags. JC Share this post Link to post Share on other sites
