12 posts in this topic
I am noticing a problem where i am using MOV instruction and writing literal text into source and String datatype in destination. It works fines in one program but doesn't on another it show an error Invalid Data Type. Argument must match Parameter Data type. I know what the error is and why but my question is why is it working perfectly fine in 1 program and not on another.
Are both machines running same firmware?
1 person likes this
yes the firmware is 34.11 but the one without error is a 5069-l320 PLC and the one with error is 1769-L36erms.
Support for literal strings is relatively new. My guess is the older compact logix cpu doesn't support them.
1 person likes this
Then how come we move or copy strings(texts) in studio 5000
You can copy strings from one string to another. 'Literals' or 'constants' were only available in last few years.
2 people like this
Well then in that case I will make an AOI and use them wherever required.
Not sure how an AOI will help.
Make an array of STRING[] data type and populate them with the  ASCII data you require, then just copy the data from the array to the register you want.
1 person likes this
I HAVEN'T USED STUDIO5000 MUCH SO NOT FAMILIAR WITH IT. CAN YOU SEND A SCREENSHOT SHOWING HOW? WHAT I HAVE DONE IS CREATED A STRING AND I CAN MOVE VALUES FROM ONE TO ANOTHER.. BUT IF I CREATE AN ARRAY WHERE DO I WRITE MY TEXTS TO THE WHOLE ARRAY AT ONCE?
Can we only write Value to string When Online??
Edited by SSrikakolum
You can do it offline as well in the Controller Tags > Monitor Tags section, then download to PLC.
Chelton is telling you to create a new String array tag then populate it with your static texts. Then in your program COP String[x] to String.
1 person likes this
