Posted 18 Nov 2023 (edited) Hi, I appreciate any advice how to deal with this problem "not support for current model type or firmware version". This message pop up in ISPSoft when want to download program from PLC to PC. WPLSoft doesn't work too, message here : "unknown device" COMMGR - recognize COM port, autotunning OK model DVP-12SA211T btw. uploading doesn't work aswell Edited 18 Nov 2023 by pjw Share this post Link to post Share on other sites
Posted 19 Nov 2023 (edited) You should check if the communication settings of the software are correct (model type in particular). Other reason could be wrong PLC MPU inside the package (aftermarket PLC board inside an DVP12SА package). I have had such cases. You may also have such problem if using improper USB<->RS-485 converter. Edited 19 Nov 2023 by IvanBratanov Share this post Link to post Share on other sites
Posted 19 Nov 2023 In case everything with the RS-232 or RS-485 converters used is OK, you should also check the firmware version of the PLC. If there is an older PLC you should find an older version of WPL for example. Share this post Link to post Share on other sites
