Posted 2 Oct 2023 I have a gt2310_vtbd and i want creat recipe but i cant find Recipe from object . Share this post Link to post Share on other sites
Posted 2 Oct 2023 Did you check your version of GT Designer3 software? Latest available is version 1.302Q Share this post Link to post Share on other sites
Posted 2 Oct 2023 20 minutes ago, VeeB said: Did you check your version of GT Designer3 software? Latest available is version 1.302Q GT designer3 version 1.151H I don't think this problem is related to the software version Share this post Link to post Share on other sites
Posted 3 Oct 2023 According to the manual you will need a newer version (1.55M or later) Share this post Link to post Share on other sites
Posted 3 Oct 2023 VeeB, where is possible to find what is new in any released version? I can see your print screen where is mentioned some manual but which manual is it please? I am interesting in GX Works2 and GT Designer3. When a new version of GX Works2 or GT Designer3 is released by Mitsubishi, where can I find what is new in that version? Thank you. Share this post Link to post Share on other sites
Posted 4 Oct 2023 The print screen above is coming from the Mitsubishi Electric e-manual viewer. After installing the e-manual software (no licence needed), you can download / add the manuals section by section. (Servo, HMI, Engineering software etc) Info on the GOT added functions: GT Designer3 (GOT2000) Screen Design manual, section 12.17 (upgraded additional function list) https://www.mitsubishielectric.com/dl/fa/software/update/plc/0000000373/e-manual_viewer_127d.zip Share this post Link to post Share on other sites
Posted 5 Oct 2023 Perfect, thank you VeeB! Yes, I use e-Manual Viewer often but I didn't noticed that chapter in the Screen Design manual. Again thank you, very appreciated. Share this post Link to post Share on other sites
Posted 6 Oct 2023 On 10/4/2023 at 9:39 AM, VeeB said: The print screen above is coming from the Mitsubishi Electric e-manual viewer. After installing the e-manual software (no licence needed), you can download / add the manuals section by section. (Servo, HMI, Engineering software etc) Info on the GOT added functions: GT Designer3 (GOT2000) Screen Design manual, section 12.17 (upgraded additional function list) https://www.mitsubishielectric.com/dl/fa/software/update/plc/0000000373/e-manual_viewer_127d.zip On 10/3/2023 at 10:11 AM, VeeB said: According to the manual you will need a newer version (1.55M or later) Where can iget it? I didn,t find anything on the internet Share this post Link to post Share on other sites
Posted 6 Oct 2023 A presume you are looking for the GT Designer software? I suggest you use the latest version with is available here: https://www.mitsubishielectric.com/fa/download/software/index.html Share this post Link to post Share on other sites
Posted 8 Oct 2023 On 10/6/2023 at 6:07 PM, VeeB said: A presume you are looking for the GT Designer software? I suggest you use the latest version with is available here: https://www.mitsubishielectric.com/fa/download/software/index.html Thanks Share this post Link to post Share on other sites
