Posted 6 Sep 2023 Hello, I have problem with Import and Export data from PLC to USB drivers. I want to write script in Subroutine and I have working script in VB language from the Tia portal, Script is in the attachment but when I want to copy the script to Sysmac it gives many errors. Please give me some advice, how to write such a script. CsvToDB.txt DbToCsv.txt Share this post Link to post Share on other sites
Posted 7 Sep 2023 (edited) Edited 7 Sep 2023 by ArturPL Share this post Link to post Share on other sites
Posted 7 Sep 2023 What made you think Sysmac studio supports VB? The screen shots suggest you are trying to place VB into a Structured Text PLC program. In a PLC program, you have to use structured text syntax, not VB syntax, and call the platform's SD memory card instructions. You should get the manuals W501 and W502 from Omron. Ah, NA HMI, not a PLC. I'm not sure what it supports, but looks like it is very different from Siemens. Share this post Link to post Share on other sites
Posted 7 Sep 2023 I will try to put VB script in NA5 because I found an article where: I have no other way to flip data between PLC and USB drivers. I have no experience with Omron PLC. Thank you in advance for your help. Share this post Link to post Share on other sites
Posted 7 Sep 2023 Hello, Siemens HMI's using VB Script language which is different than VB.Net language. You can't just copy and paste scripts from Tia Portal to Symac and vice versa. Search on the forum. Somewhere there is an example of script to copy files between locations. Share this post Link to post Share on other sites
Posted 8 Sep 2023 Hello Realisator, Okay, I didn't notice the difference. Share this post Link to post Share on other sites
Posted 28 Oct 2023 Hello everyone I managed to write an import export script for data structures. If anyone needs help on this topic, please send me a message. Share this post Link to post Share on other sites
