Posted Friday at 6:05 AM (edited) Hello; Need some information about the correct procedure of replacing an I/O TM2AMI4LT module. My problem: have 3 same modules TM2AMI4LT and I think someone changed their position. Now the system is showing multiple errors on HMI display. Therefore, machine stays on hold, safe lock. What I like to know is; Do I need to upload the application of the system after I have replaced a I/O module ? Second question: If I replace a I/O TM2AMI4LT module for a new one, does the system will function as before after startup, this without an upload? Last question: Does an I/O TM2AMI4LT contains a “fixed” software address, once programmed? Hope to read your advise soon. Edited Friday at 6:07 AM by HappyMe10 Share this post Link to post Share on other sites
Posted Monday at 2:10 PM Hello, You can swap the module without the need to download the application. There's nothing into the module, the whole wonfiguration is in the plc. JC Share this post Link to post Share on other sites
Posted 23 hours ago Thanks a lot! , This helps me forward! One problem resoved. Share this post Link to post Share on other sites
