Posted 10 Jun 2022 Hi to everyone, I have a question. Why when I disconnect an analog sensor from NX-AD2204 the card sets fault bit even when I changed event level setting. I checked when the sensor goes out of range or gets disconnected the Fault bit for the unit card sets ON. I have checked troubleshooter and I don't see any warnings or faults, only status change as observation message. Anybody was able to make it working properly? Thanks in advance! Scotty Share this post Link to post Share on other sites
Posted 13 Jun 2022 So you're looking for a minor fault when a sensor is disconnected? One that appears in the troubleshooter? Or you are trying to disable this feature? Share this post Link to post Share on other sites
Posted 13 Jun 2022 I thought that error state from the unit itself will be in ON state only when error is present, not when notification messages are present. Is it a way to make error fault status react only on errors not on every state change in the unit? Share this post Link to post Share on other sites
