Posted 30 Jan 2022 Hello guys Could anyone kindly assist me with solving this task i attached on this post . Its related to the stepper motor and i have tried to understand whats going on with CX programmer but im facing difficulties in programming this instruction .Thank you in advance to those who will help!!! Share this post Link to post Share on other sites
Posted 30 Jan 2022 Maybe you could elaborate a bit on this... Am I correct in assuming you need an output on when the axis is between 5 and 15 and off outside of this range? 2 people like this Share this post Link to post Share on other sites
Posted 30 Jan 2022 need to post some info on used hardware (CPU type), addresses used to control stepper, number of steps per revolution etc. normally steppers are controlled by PTO (pulse train output) which need to be configured. check instruction manual for your controller Share this post Link to post Share on other sites
Posted 3 Feb 2022 (edited) On 1/30/2022 at 8:55 PM, panic mode said: need to post some info on used hardware (CPU type), addresses used to control stepper, number of steps per revolution etc. normally steppers are controlled by PTO (pulse train output) which need to be configured. check instruction manual for your controller On 1/30/2022 at 6:45 PM, photovoltaic said: Maybe you could elaborate a bit on this... Am I correct in assuming you need an output on when the axis is between 5 and 15 and off outside of this range? yes that is correct i have to design a program that will run the program on the stepper motor uisng Cx programmer PLC Edited 3 Feb 2022 by Zimmy Share this post Link to post Share on other sites
Posted 3 Feb 2022 On 1/30/2022 at 6:45 PM, photovoltaic said: Maybe you could elaborate a bit on this... Am I correct in assuming you need an output on when the axis is between 5 and 15 and off outside of this range? yes that is correct i have to design a program that will run the program on the stepper motor using Cx programmer PLC Share this post Link to post Share on other sites
