Posted 29 Feb 2020 Hi Friends, I am in a requirement to control huge nearly 300 channels Analog in a system. That is through PLC i need to give a Voltage output for 250 channels. Which Configuration will suitable for this requirement. Is it possible? Any difficult is their in controlling this much Analog output in PLC? Kindly advice me.. Share this post Link to post Share on other sites
Posted 2 Mar 2020 The amount of channels is not an issue. You will need an iQ-R system for all the analog cards or you have put them on remote IO. Share this post Link to post Share on other sites
Posted 4 Mar 2020 (edited) On 3/2/2020 at 2:08 PM, Gambit said: The amount of channels is not an issue. You will need an iQ-R system for all the analog cards or you have put them on remote IO. Ok sir thank you. We are planing to go for Q series PLC . Did you used any application with this much Analog .Can you able to share the Configuration details. Edited 4 Mar 2020 by krishna k Share this post Link to post Share on other sites
Posted 4 Mar 2020 Hi Why use a old platform like Q series? What about spare parts after 10 years? In the IQ-R system you do not need any code for normal analog handling like filtering and scaling. Good luck:-) Share this post Link to post Share on other sites
Posted 4 Mar 2020 2 hours ago, GreenMan said: Hi Why use a old platform like Q series? What about spare parts after 10 years? In the IQ-R system you do not need any code for normal analog handling like filtering and scaling. Good luck:-) hi, yes i too thinking for IQR.. thanks.. Share this post Link to post Share on other sites
