Posted 28 Feb 2020 (edited) hi all, i'm currently trying to shift register some data in the floating point (double word) format, just for an example i,m using a 0-20mA 0-40 bar pressure sensor to gather information from a can filler and want to log the data for lets say the previous 20 cans. i understand how the shift register works and can get it to work with single word just fine, im using floating point to make my life a bit easier by using sleepy wombat's scaling function block, i need decimal points as i will be expecting reading around 4.5 or so bar and expected to be within .2 tolerence this will then have to displayed on a HMI, which i assume will be easy enough Edited 28 Feb 2020 by Bobodopalus Share this post Link to post Share on other sites
Posted 28 Feb 2020 Take a look at the XFER instruction. gtsuport Share this post Link to post Share on other sites
Posted 28 Feb 2020 i did take a look at that, it can move an amount of words but only to a fixed data location right? so i could move my doubleword from d120 to d220, but it would not shift upon more entries, i would always be replacing d220 and not shifting from d220-d222-d224 etc Share this post Link to post Share on other sites
Posted 28 Feb 2020 (edited) N = size of data required, 40 for 20 cans. Source D120 Destination D122 After XFER, move new data into D120 After XFER is executed again, all data is shifted by 2 registers. gtsuport Edited 28 Feb 2020 by gtsuport Incorrect value for N Share this post Link to post Share on other sites
