Posted 5 Feb 2020 Dear All, I have a problem in MX Component (Communication setup Utility) Software.When I am going to setup This Software.Every Time Show Error Message.The Message is in attached File. I used FX 3G PLC.What i done that i given Bellow through the sequence by sequence______ 1.Click The wizard Button of Communication setup Utility. 2.select logic station number. 3.USB select 4.Select FX 3G CPU 5.Select Host Station 6.Write Comments.Then Click Finish Button. but show the Error Message. Please Give the solution.Thanks In Advance. Share this post Link to post Share on other sites
Posted 6 Feb 2020 It would be good if you than also post the solution which would be running the software as administrator I expect. Share this post Link to post Share on other sites
