DrBoom88
Cp1h-y - encoder issues.
4 posts in this topic
My issue and goal. - Trying to get an encoder (Automation Direct TRD-N30-RZVWD) connected to a cp1h-y to read wheel position(coupling) and have a pulse trigger at certain positions is this possible?
I currently have the encoder wired up to highspeed counter 1 and am using PRV(881) port #0010 control data #0 with an P_On always on flag.  wanting to see  values change but nothing is being changed in the watch window. I'm reading the programming in section  3-20-2 HIGH-SPEED COUNTER PV READ: PRV(881), but I'm struggling.  any help is much appreciated.
Have you looked at section 5-2 of the CP1H Operation Manual (W450)?
You'll need to configure Settings for the 'Built In Inputs'. There are 4 channels for HSC, make sure your wiring is correct for the appropriate channel. For channel 0, the pulses will count in memory address A270 - 271.
Yes sir,
I'm all correct as far as I can tell. maybe I should try a different encoder?.
Wiring  W450 manual
