ThePLCPeon
Simulation of PID block in GX Works2 [Resolved]
2 posts in this topic
Hello, I am trying to simulate the PID block in GX Works2. I have the project setup for use with a FX3G PLC, I am unable to get any form of output from the block when setting it up.
I am using the FXCPU Structured programming manual pages 414-417. My first question is, is it possible to simulate this block?
Below is my current setup, I have assigned D500 to the parameter values, this uses D500-D528 to store the parameters.
Target value set to 100 and Actual value set to 10(The actual value wont change, I just wanted to get some output change in response to the PID trying to achieve 100)
S3(D500) set to 100ms
S3+1 bit 5 set to 1 (required to set the output upper and lower limit)
S3+3 set to 10000(again purely looking for any response just to confirm it is working)
S3+22 set to 32767 (output upper limit setting value)
S3+23 set to 0 (output lower limit setting value)
So thats my current setup, thanks.
Solved: I downloaded some sample code of PID fro mthe mitsi website, this particular filw was labelled PIDFx_100 and it contains a program labelled "SimplePID" this is what I used.
I needed to import the library in my current project to allow me to select this function block, after some minor changes I was able to simulate with no problem at all. If anyone reads this and wants any help feel free to message me and I will reply when I can.
Edited by ThePLCPeon
Hi,
Could you help me to implement the PID simulator in GX Workx2?
I require the file PIDFx_100 that you say , and how did you import the library in order to select this function block
Thanks
