Posted 25 Oct 2017 (edited) Dear Sirs, I have GE PLC system of type series six plus programmable controller, the enabled led of the I/O control card always off therefore the overall outputs are disabled I need your help to solve this problem. Thanks Edited 25 Oct 2017 by ahelwa I uploaded some photos Share this post Link to post Share on other sites
Posted 25 Oct 2017 Check the "Troubleshooting" Chapter of the manual GEK-96602A which you can find in the GE Downloads section of this website. You may have to get online with a computer running Logicmaster Six software to clear errors. Share this post Link to post Share on other sites
Posted 29 Oct 2017 Dear Mr. Steve Bailey Thanks for your reply I cleared all of faults with the work master station but this fault (enabled) still exist I think it is a hardware fault and I read the manual but I can't found a solution. Share this post Link to post Share on other sites
Posted 30 Oct 2017 The simplest thing to try is to remove/reseat all of the modules in the rack. Be sure to use the insertion/extraction tool to get them seated as tightly as possible. Also check the ribbon cable between the Arithmetic Control module and the Logic Control module. After that, replace modules in the order indicated in the manual. If you don't have spares in stock, be vary careful to purchase replacement modules that are compatible with the ones you have. Seriously, you need to make a plan to replace the Series Six. I was a young man when it was introduced. I'm not young anymore. Share this post Link to post Share on other sites
Posted 2 Nov 2017 Dear Mr. Steve, Thanks for your reply I connected the Workmaster and I found error flags: 11110100 10010110 10000001 00000000 and table parity error 0096 and the CPU refuses to switch to run state. it switches back to stop state with a sound of relay tick less than a second after pressing F3 from the Logcmaster Share this post Link to post Share on other sites
Posted 2 Nov 2017 It is almost certainly a hardware problem. If removing/reseating the modules does not get you running again, the next step is to start replacing modules. The module most likely to have failed is the combined memory module. Unfortunately it is also the most expensive. Here is a place in the United States where you can get spare parts: http://www.cimtecautomation.com/parts/c-40-series-six.aspx?pagenum=5 Share this post Link to post Share on other sites
