Posted 21 Jan 2017 I have a CQM1-41EV controller, with 4 IA121 input modules, and 2 OC222 output modules. When in monitor mode, I can operate buttons, switces, and everthing shows that it is working. However when I go offline, and do a reboot, the outputs will not come on! What did I do wrong? Share this post Link to post Share on other sites
Posted 21 Jan 2017 1. Is the CPU RUN light on? 2. Is there a memory card in the slot behind the door to the cpu? 3. Is the INH light on? 4. Is there a cable attached to the peripheral port on the CPU? Share this post Link to post Share on other sites
Posted 21 Jan 2017 The RUN light is on. There is no memory card. The INH light is off. The peripheral port has the programming cable in it. The input and output cards all have the ready light on, and I have 2 inputs on. The comm port is talking to the screen. Share this post Link to post Share on other sites
Posted 21 Jan 2017 Quote The peripheral port has the programming cable in it. The CPU responds to whatever the peripheral port has attached. Set the Mode to either RUN or Monitor on Startup. Share this post Link to post Share on other sites
Posted 21 Jan 2017 Quote The RUN light is on. Post your program. Share this post Link to post Share on other sites
Posted 22 Jan 2017 I have the setting set for run. I am using CX-One for programming, I have tested it with and without the cable attached. This is not my first PLC, however, I have never had thi8s happen!! Share this post Link to post Share on other sites
Posted 22 Jan 2017 Ok here are the files. Thank you Jay! HOP_ROTARY.cxp HOP_ROTARY.opt Share this post Link to post Share on other sites
Posted 22 Jan 2017 My bad Jay!! I have reverted to my old Rockwell days! The output numbers are wrong!!! Share this post Link to post Share on other sites
Posted 22 Jan 2017 No problem, buddy! For those of you who are following this thread: CQM1 Inputs start at 0.00 CQM1 outputs start at 100.00 1 person likes this Share this post Link to post Share on other sites
Posted 22 Jan 2017 I have to tell you, this is a lifesaver! I don't think my head could pound the wall much longer! I sent the same thread to Omron, a week ago, and have not heard from them!! You guys are the greatest! Share this post Link to post Share on other sites
Posted 1 Mar 2017 hi, please chuchc how can i read analog input from cqm1 ,and how i can do scaling ? Share this post Link to post Share on other sites
Posted 2 Mar 2017 Do you have an analog input card? Do you have an IPS01 Analog Power Supply card? Share this post Link to post Share on other sites
