ilsk8
NS5 cables
5 posts in this topic
Hello there everybody, I have a small problem with cables. I am building a collage project and am using a CPM-1A connecting to a NS5 screen via a C1F01 RS232 adapter. I have the cables to connect from PC (Syswin) -> C1F01 RS232 adapter -> PLC and PC (NS designer) -> NS5 screen. Here is the problem! As the 9 pin plugs on the NS5 and RS232 adapter are both male connections, I do not have the right cable to connect the PLC to the Screen via the adapter. Is there a wiring diagram available so I can make the RS232 cable with female ends linking the adapter and the screen? Thanks in advance Rod. :-8
Buy a gender bender. They are very cheap.
Thanks for the reply, but witch cable do I use to link the screen to the RS232 adapter. The cables I have are XW2Z-S002 RS232C Edited by ilsk8
Download the following file from MrPLC.com and look for C200H-CN320-EU. This is the cable that you can use to connect the NS5 to your PLC. The cable diagram is also shown if you want to make your own cable. Omron Serial Cables @ MrPLC.com
NICE ONE!!!!!!!!
