Posted 17 Sep 2012 is you want more then the standards 8 words x 2 - then you could use a send receive response... ie use word L0 as the word that tells which frame of info you are sending... set up you initial set of words then put a 1 in L0 for set one...in PLC two copy the L0 to L8 then read back L8 and if = to L0 then write the next set of words to Lset L0=2 and repeat... a bit like a multiplexer... a bit of coding, but it can work... Share this post Link to post Share on other sites
Posted 17 Sep 2012 (edited) iwill try multiplexer ..bit thanks plz give us 1word exmple but what about sand commoned from slave plc as txd to master rxd posible Edited 17 Sep 2012 by hussian Share this post Link to post Share on other sites
Posted 6 Nov 2012 (edited) which plc ican use as safe load indictor as on cranes ( angle sig,len sig,max load ,act load ) SLI UNIT no any one can reply my post >>>>/???????????? ICAN USE HOIST LINK TO LINK 2PLC CPM2A WITH OUT USE THE SLAVE /MASTAR SET...? Edited 15 Nov 2012 by hussian Share this post Link to post Share on other sites
