Posted 29 Feb 2012 Hi, I have a application, where is 100 different products. Operator chooses the correct program from the push wheel ( http://uk.farnell.com/te-connectivity-alcoswitch/dps9131ak/switch-digital-push-wheel-bcd/dp/1701060) . PLC reads the code and activates according to the number on the push wheel a memory bit e.g. M60.0 . When the operator changes the program from the push wheel , the I need to reset the machine and reset some memories. I found a easy solution for it. I made added an OR instruction, with 100 inputs. In every input is a positive edge instruction. One for every product. So I have 100 positive edge instructions here. M60.0 - M69.7 M100.0 - M102.3 Is there a way to make this big OR instruction shorter or replace with some special function? Share this post Link to post Share on other sites
Posted 1 Mar 2012 If they are dialing in a number in BCD, can't you just do a compare in the program to see what number was dialed in? When you start a product, store the number to a register. Then when the number on the wheels doesn't match the stored number, do your resets and preparation for the next number and then overwrite the saved number. Share this post Link to post Share on other sites
Posted 11 Mar 2012 (edited) You could write your own function to check for a BIT turning on - Edge evaluation, rising, word by word L MW 150 //Load old input value (edge memory bit) L MW 60 //Load input value T MW 150 //Transfer current input value into old value (edge memory bit) XOW //Link old value and input value using "EXCLUSIVE OR" L MW 60 //Load input value AW //Link result with input value using "AND" T MW 102 //Transfer result to "rising" pulse memory word L 0 <>I = M 0.1 M0.1 will be "HIGH" for one program scan every time a bit goes HIGH in the word MW 60. Just repeat the code for every MW you want to check. This was written for an S7 300; STL/IL is not supported in the 1200 but should convert easily. Use of a MD will check for 32bits at a time instead of 16bits at a time with MW Edited 11 Mar 2012 by Moggie Share this post Link to post Share on other sites
