NoBoots
Serial communication cpm2a
2 posts in this topic
I'm searching for a way to set an output on my cpm2A with my pc (true RS232). In the manual i found a bunch of commands but not one i can use when the plc is in run state (I can connect my pc to the plc, and use these but i can figure out what to use to set an out- / input) Greetings, Geert
You can utilize Serial Communications using Host Link protocol. This is discussed in Section 4 in the manual W353 "CPM Series Programming". Be aware that the PLC must be placed in the Monitor Mode to fully utilize this protocol.
