sammy
analog signal generater
14 posts in this topic
I just bought a NI4 card to learn how to do it and I thought that I had some thing a round the house here to generate a signal but I cant find it. I do have some thermocouples here also. Is there a way to make an inexpensive one or buy one? I looked on the forums cuz I thought there was some thing posted once. Thanks Edited by sammy
Try this one, it may work and it cost only 20.0 bucks from Macmaster carr. It generates a small signal ( in the range of 50mv to 1 or 2 volts ) depending on the temperature you try to monitor but enought to trigger your N140 card. http://www.mcmaster.com/#3648K22. You also can use a Trim Pot and one or two resistances connected to a 24VDC Power Supply to generate a signal in the range of 0-10 VDC. The trim Pot and Resistances can be found in any electronic supply or Radio Schack.
NI4O ??? Are you sure about that catalog number. Can you double check it and repost the complete catalog number?
Any analog transmitter calibrator will do it. Even the cheapest one should be able to generate at least 0-10VDC and 0-20mA.
Try this one. http://www.mcmaster.com/#3648K24
It is a type K thermocouple, works the same way as the previuos, the cost is the same.
Robert, the 1746-NI4 analog input card is a voltage/current card with ranges, see picture below. It won't do much with a millivolt input.
Getting a thermocouple is no problem, there a dime a dozen, but as Mickey said I need a power supply for the analog signal. The p/n you gave me is for a t/c and not a power supply. Thanks any way. Sam Edited by sammy
Here's another thread on the subject. http://www.plctalk.net/qanda/showthread.php?t=45341
many most SLC power supplies have a 24 VDC source built in ... open the door on the Power Supply and see if you have an extra two screws under there - marked accordingly ...
Mickey is right, this card won't do much with a milivolt signal since the range is from 0 to 10 volts. I think you best bet is opcion B, a 24 power supply with a trim Pot or variable resistance.
Found an easier way to do it: 6 aaa batterys, and 1 load cell and hook it up to my analog card. Now I can see what it does.
Have a look at our analog simulator generator. It does 4-20ma and 0-10VDC. Not quite are cheap as 6 AAA batteries but quite useful. I keep one in my bag all the time. http://www.theautomationstore.com/index.php?page=shop.product_details&flypage=flypage_images.tpl&product_id=4&category_id=2&option=com_virtuemart&Itemid=2
