Posted 13 Oct 2010 Hi all. I have a simple question but i don't find a solution... In the past when I used Citect v6.1, after program compilation I had a screen with used tags. It's possible to have it too on V7? Probably i dont remember the correct setting. Im coming crazy:helpme: thanks!!!! Share this post Link to post Share on other sites
Posted 14 Oct 2010 (edited) It might not be in there anymore since Citect V7 uses dynamic tag counting. Only the tags used when running the apllication are counted. For instance: you can now run a project with 1000 tags with a 75 tag license. Only when you've vieuwed/ trend ..etc more than 75 tags Citect will then shutdown. You can now have a Alarm viewer of all the alarms in a system with the smallest tag count key!!! Edited 14 Oct 2010 by Gambit Share this post Link to post Share on other sites
Posted 14 Oct 2010 Thanks. I found this function to read actual used tags CitectInfo("General", "", 29) The result of this funcion is the sum of all tags working actually on the plant? In example:when i start working I have zero and step by step, calling and using variables, this increases? Thanks again! Share this post Link to post Share on other sites
