Posted 16 Oct 2008 Does Gx Developer has option of going true the program step by step? And can inputs or marcers be set to 1 while/betwin doin this? Share this post Link to post Share on other sites
Posted 19 Oct 2008 You can't run the program step by step in a PLC, however with the GX Simulator package you can on your PC. GX Simulator installs into GX Developer (but is sold separately). Share this post Link to post Share on other sites
Posted 27 Oct 2008 you can write your own code that will execute in stages or run until condition is met (such as button "next" pressed). since i have GX Developer (not IEC). should have some sequencer samples in download section... Share this post Link to post Share on other sites
Posted 28 Oct 2008 yes i could be the resolution Thank you i'll try Share this post Link to post Share on other sites
