Posted 18 Jan 2008 Hi all, I am planning to use Omron PLC (CQM1-CPU21) with Labview 7.1. Just I need to read the cycle count from PLC via RS 232 communiction. Is that possible? If yes, What is the cycle count read command or Where I can found these info. Thanks Jey Share this post Link to post Share on other sites
Posted 21 Jan 2008 If you mean the scan time of the program then sure... AR27 If labview can;t read that area.. in the PLC program xfer the value to a DM area.. lab view should be able to read that. Refer to the CQM1 Programming Manual.. -> Memory Areas -> Appendix C... for more details. Share this post Link to post Share on other sites
Posted 10 Mar 2008 my understand with your question are , you need to use labview write and read data from omron plc. ok if it correct, now labview is hmi and plc is hardware .what is communition between lapview with plc. in labview v8.5 , it have function opc client that can read and write data from opc server . now i use kepware for opc server and config kepware commu to plc by fin ethernet . it work ok stable and high espeed. result if you need used labview for read and write data any plc then you need to use opc server Share this post Link to post Share on other sites
