Jump to content
Timer percent complete
  • Please log in to reply
11 replies to this topic
#1 screaminlean
screaminlean
    Sparky
  • MrPLC Member
  • PipPipPip
  • 15 posts
  • Gender:Male
  • Country:United Kingdom
    United Kingdom
Posted 15 April 2012 - 06:11 AM
Hi Me again
I have my program almost done thanks to peeps here all i need to do now is figure out how to Calculate percent complete and mov to D0010?
Set value for the timer is in D0001 and Timer value is T0000
I made a function block ST but have no idea how to hook up the timer to execute it and the output result moved to D0010 I have attached a sceen shot of the function so far.
Thanks in advance
Here to learn, I have not had any training or done any courses so I may be asking basic questions but we all have to start some place
I have VB.net, C#, Perl and PHP experience so if you need any help with thoselet me know!
#2 screaminlean
screaminlean
    Sparky
  • MrPLC Member
  • PipPipPip
  • 15 posts
  • Gender:Male
    United Kingdom
Posted 15 April 2012 - 08:37 AM
Hi Me again
Thanks in advance
Ok I tried to use
TIM 0000 N01_psv
AND P_0_1s
/B(434) T0 N01_psv D10
so every 0.1 seconds that the timer is active the calculation is done and pushed to D0010 but this will not be any good as a timer counts down! anyone done this before?
Edited by screaminlean, 15 April 2012 - 10:39 AM.
#3 screaminlean
screaminlean
    Sparky
  • MrPLC Member
  • PipPipPip
  • 15 posts
  • Gender:Male
    United Kingdom
Posted 15 April 2012 - 10:49 AM
All I can think of doing is
X = TimeDone
Y = % Complete
so
X = Timer Set Value (SV) Minus Timer Current Value (T0)
Y = X Divided by Timer Set Value(SV)
But how to implement this on the ladder?
#4 ParaffinPower
ParaffinPower
    Sparky
  • MrPLC Member
  • PipPipPip
  • 411 posts
    United Kingdom
Posted 15 April 2012 - 11:21 AM
X = TimeDone
Y = % Complete
so
Hello
If you use a timer within your ST, then you can do the maths in there too. Much easier than fannying aobut with maths in ladder imho.
TIMHX(StartCondition,MyTimer,TimerValue)
#5 screaminlean
screaminlean
    Sparky
  • MrPLC Member
  • PipPipPip
  • 15 posts
  • Gender:Male
    United Kingdom
Posted 15 April 2012 - 11:59 AM
X = TimeDone
Y = % Complete
so
Hello
Dont know how to use ST functions and I have 4 timers i need to do the same with see attached this is my program so far rung 06 is the first instance
Edited by screaminlean, 15 April 2012 - 12:03 PM.
#6 lostcontrol
lostcontrol
    Sparky
  • MrPLC Member
  • PipPipPip
  • 427 posts
  • Country:New Zealand
    New Zealand
Posted 15 April 2012 - 02:28 PM
Try this, copy this into the mneumonics view of CX-P.
' Steps to calculate % done of Timer\n 1. Convert Timer Preset to Float\n 2. Subtract Preset from PV to get timer value as incrementing\n 3. Convert result to Float\n 4. Divide (Preset - PV) by Preset to get %\n 5. Multiply by 100 to get whole no %\n.
LD P_On
OUT TR0
AND 23.00
TIMX(550) 0000 D0
FLT(452) D0 D10
// Convert to Float
-(410) D0 T0 D12
// Subtract
FLT(452) D12 D12
// Convert result to Float
LD TR0
/F(457) D12 D10 D20
// Divide by Preset
*F(456) D20 +100.0 D20
// Multiply by 100 to get value as %
#7 screaminlean
screaminlean
    Sparky
  • MrPLC Member
  • PipPipPip
  • 15 posts
  • Gender:Male
    United Kingdom
Posted 16 April 2012 - 05:40 PM
LD P_On
OUT TR0
AND 23.00
TIMX(550) 0000 D0
FLT(452) D0 D10
// Convert to Float
-(410) D0 T0 D12
// Subtract
FLT(452) D12 D12
LD TR0
/F(457) D12 D10 D20
// Divide by Preset
Thanks alot thats great!!
#8 screaminlean
screaminlean
    Sparky
  • MrPLC Member
  • PipPipPip
  • 15 posts
  • Gender:Male
    United Kingdom
Posted 02 November 2012 - 11:29 AM
LD P_On
OUT TR0
AND 23.00
TIMX(550) 0000 D0
FLT(452) D0 D10
// Convert to Float
-(410) D0 T0 D12
// Subtract
FLT(452) D12 D12
LD TR0
/F(457) D12 D10 D20
// Divide by Preset
After bieng able to sign in to the site i Can post again!
I still cant get this to work right? I have NQ5 with bar graph set to UINT and my timers are TIMHX(551) CP1E so cant use function blocks or ST.
any easier ways?
Regards
#9 Michael Walsh
Michael Walsh
    Omron Expert
  • MrPLC Admin
  • 503 posts
  • Gender:Male
  • Country:United States
    United States
Posted 02 November 2012 - 01:40 PM
This code (same as above, except with TIMHX) should work just fine. I just tested it in simulation mode.
LD P_On
OUT TR0
AND 23.00
TIMHX(551) 000 D0
FLT(452) D0 D10
// Convert to Float
-(410) D0 T0 D12
// Subtract
FLT(452) D12 D12
LD TR0
/F(457) D12 D10 D20
// Divide by Preset
I am guessing that your HMI is not set to read D20 properly. You need to make sure that you set your graph to read D20 as a REAL or FLOATING POINT number. Make sure to monitor it in CX-Programmer as a REAL number also.
In the three different cases shown the percent done value (Real number in D20 is correct).
1st case: (D0 (setpoint) - T0 (current value)) / D0 (setpoint) -> (2000 - 1854) /2000 = 7.3 (%) which is stored in D20.
2nd Case: (2000 - 1042) / 2000 = 47.9 %
3rd Case: (2000 - 353) / 2000 = 82.35 %
It works, you must have a number format issue somewhere in your HMI or in your ladder. If you are doing a MOV instruction after the math, make sure to do a MOVL as a REAL number is a double word (meaning that it is contained in D20 and D21 in this example).
Michael
Charlotte, NC
#10 screaminlean
screaminlean
    Sparky
  • MrPLC Member
  • PipPipPip
  • 15 posts
  • Gender:Male
    United Kingdom
Posted 02 November 2012 - 02:21 PM
Hi I got the same result now in the plc thanks, I have only 4 options for the number format in the NQ5 HMI
  • Unsigned Int
  • Signed Int
  • BCD
  • Hex
And current seeting in the HMI is Unsigned, can i get a conversion from REAL to Unsigned? Multiply it by 10 using *F(456) Floating point multiply?
Regards
Pete
Edited by screaminlean, 02 November 2012 - 02:25 PM.
#11 Michael Walsh
Michael Walsh
    Omron Expert
  • MrPLC Admin
  • 503 posts
  • Gender:Male
    United States
Posted 02 November 2012 - 03:04 PM
If you want whole percent values as an integer (ie 25%, 50%, etc.), use this:
LD P_On
OUT TR0
AND 23.00
TIMHX(551) 000 D0
FLT(452) D0 D10
// Convert to Float
-(410) D0 T0 D12
// Subtract
FLT(452) D12 D12
LD TR0
/F(457) D12 D10 D20
// Divide by Preset
FIX(450) D20 D25
If you want integer values that represent tenths of a percent (so that 25.2% is 252), then use this:
LD P_On
OUT TR0
AND 23.00
TIMHX(551) 000 D0
FLT(452) D0 D10
// Convert to Float
-(410) D0 T0 D12
// Subtract
FLT(452) D12 D12
LD TR0
/F(457) D12 D10 D20
// Divide by Preset
*F(456) D20 +1000.0 D20
// Multiply by 1000 to get value as tenths of a %
FIX(450) D20 D25
Then display D25 on your screen as an Unsigned Integer format. Of course if you use the tenths of a percent example (2nd set of code), you will need to scale the display by 10 to get the decimal in the proper place.
Michael
Charlotte, NC
#12 screaminlean
screaminlean
    Sparky
  • MrPLC Member
  • PipPipPip
  • 15 posts
  • Gender:Male
    United Kingdom
Posted 03 November 2012 - 03:52 AM
Michael Walsh you are an absolute Diamond, Thanks so much it works now!!!! FIX(450) did the trick and I totally missed that!
Download » CX-Programmer
    No categories found.
Store » CX-Programmer
Articles » CX-Programmer
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
