Factory Talk Studio Error
  • Please log in to reply
2 replies to this topic
#1 Armadillo852
Armadillo852
    Sparky
  • MrPLC Member
  • PipPipPip
  • 191 posts
  • Gender:Male
  • Country:United States
    United States
Posted 17 February 2011 - 04:20 PM
I recently had a hard drive crash. So I put an image from another guys computer into mine. Everything is the same except the name. Everything works fine but Factory Talk Studio. I start the program. I either select an existing project or hit cancel to create a new project. Then after a few seconds I get the error. I receive the following error: An internal error has occurred. You must close the RsView and stop the RsLinx Enterprise service before continuing. Failed to initialize component manager.
I uninstalled Factory Talk numerous times. I removed my anti-virus and installed. I deleted the C:\documents and settings\all users\application data\RsLinxEnterprise folder.
I replaced the XML file with the default file.
I tried registering the dll's again.
All this per AB support and knowledgebase.
But still same error. I have attached a screenshot.
#2 fuzzy logic
fuzzy logic
    Sparky
  • MrPLC Member
  • PipPipPip
  • 91 posts
  • Country:Italy
    Italy
Posted 21 February 2011 - 08:16 AM
Please try the following:
1. RSLinx Enterprise is disabled.
Solution:
1. Go to Control Panel-> Administrative Tools-> Services.
2. Double-click on RSLinx Enterprise and change the startup type to "Automatic".
3. Start the service.
4. Run RSView Studio again and this time the error should not appear.
2. If the service is not disabled then do the following:
1. Disable the RSLinx Enterprise service in Computer manager
2. Uninstall RSLinx Enterprise
3. Remove the contains in C:\Document and Settings\All User\Application Data\Rockwell\RSLinx Enterprise
4. Reboot
5. Install RSLinx Enterprise
- fuzzy logic
#3 Armadillo852
Armadillo852
    Sparky
  • MrPLC Member
  • PipPipPip
  • 191 posts
  • Gender:Male
    United States
Posted 21 February 2011 - 09:42 AM
Solution:
4. Reboot
- fuzzy logic
Been there done that. I saw that knowledgebase as well.
I have done numerous things from deleting folders, registry entries, programs, and installing batch files. All with no success.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
