WattUp
Solved. CC Link between 2 CPU, data in buffer but fails TO/FROM
3 posts in this topic
I am trying to setup a CC Link between two machines. I have done this before without issue, but for some reason this is not going well..
I added a second CC link card to CPU2 and set it as ST 24 for the CPU1 network.
CPU 1 : Master.   cc0.jpg.   The original machine was setup using TO/From for each station, so i couldn't add this new link through the GUI.
CPU 2: Local cc1.jpg  When i try to use the GUI to setup this side the buffer stops working. but if i activate any TO/From instruction here i get a system fault with a 2110 SP. Unit Error
CPU2 buffer cc2.jpg. But when i block the TO/From you can see the buffer is working at that exact same location specified.
2110 error says I am addressing the wrong card but the buffer proves that I am not.
Edited by WattUp
Solved below
Why is your second CC-Link card set at H200?
Winner winner.
After 1 hour going through everything again I found that issue.
The second PLC card is setup and addressed as 200, but the TO/FROM command required it be H20  and always require to drop the last 0.
