Remon2000i
1747-sn scanner
9 posts in this topic
i am new in plc and i have issue with allen-bradley system image1.jpeg.216b03b025a2cd010a79cc0907d1
processor slc 503 slot 0
scanport slot1 comm led give red flasher no fault an it connected to 1336 plus (vfd).
at scanport dip switch 1&2 on baud rate 57.6
and dip switch at 1336 plus (vfd) i have three switches in remote I/O 1336-GM1  configerd as image2.jpeg.8662bd1cbc715b77d7a1b957b706
SW1: 1 OFF &2: OFF& 3:ON&4:ON&5:ON&6:ON&7:ON&8:OFF
SW2:  1:ON &2:OFF&3:ON&4:ON&5:ON&6:ON&7:OFF&8:OFF
SW3   1:OFF&2:ON&3:ON&4:ON&5:OFF&6:OFF&7:OFF:8:OFF
JUMPER J2 BETWEEN 1AND 2
at scanport terminal resistor 150 ohm
HOW I CAN MAKE SCANPORT COMMUNICATE WITH VFD 1336 PLUS ?
Is this something that has been running and now doesn't?
Is this a new install, an upgrade, etc.
What lead to this issue?
1- yes before I had  fault inside vfd serial fault (10) and I found in side vfd 3 IGBT was burn and I changed it now it working ok .
Thanks
It's very likely that whatever happened to the drive to destroy its IGBT transistors also damaged the 1336-GM1 interface board.
If there are other RIO devices on the daisy-chain network, then you can check the status bits for the 1747-SN scanner module to see if those are working correctly.
Otherwise the probable answer is to replace the 1336-GM1 interface board.    While these have not been manufactured for many years, they may be available as replacement parts from Rockwell or on the aftermarket.
Thanks for your reply in the site I have anew card from scanner and I replaced it and also not working .
I searche about 1336GM1 board and i found it on eBay site but I have doubt on it because some board written on public used .
no any  way to can assure from problem from this board ?
when I search about this problem I found this sheet .
caedf201-0bc5-44d5-9e48-a1cf0a549077.MP4
1215444485.pdf
Edited by Remon2000i
dear ken roach i found in our store anew card from 1336gm1 and i replaced it but the same issue .
what is your advice for my status ? how i can check the problem ?
thanks
best regards .
Is this the only device it's talking to??? As Ken noted if its talking to the other devices, then it's your drive.
